Question about 2wire HomePortal 100 Network Adapter
Range for my 2wire wireless router
What distance from the router can I have my second computer hooked up and receive good signal. I Am having an issue with the wireless netopia USB getting a (good) signal. The network icon on the bottom task bar indicates there is a good signal. However when I run the install disk after selecting the second coputer choice during the set up I receive a low signal and then the disk prompts me to type the last 3 digits of the SN# and then the 10 digit key. I do this and the computer states it is unable to make a connection. I have the second computer in a bonus room over my garage that is attached to the house. The 2 nd computer is around 60 to 80 feet away. What range can I expect?
tom19511
  • 1601 Answers
SOURCE: signal strenght just gone!
Are you using the same security as the others?
Make sure the the security key is exactly the same as the others.
Also check the firewall settings
Posted on Dec 29, 2007
lalaro_me
  • 135 Answers
SOURCE: Problem with 2Wire 802.11g Wireless USB Adapter
The adapter is been installed properly?
Try to check this settings on the router:
- Try to change the channel of the router (either 1, 6 or 11)
- Check the visibility status (if visible or invisible) (Under wireless settings)
- Make sure that the network filter (MAC address is turn off) (Under advance tab)
- Disable the wifi-protected setup of the router (Under advance tab)
- Then check the if you can detect the wireless network?
>>>>> lalaro_me
Posted on Mar 08, 2009
skitano
  • 3 Answers
SOURCE: 2WIRE Router, Belkin Card, and 10 vs. 13/26 digit encryption key
I would give you two options
1. to change ur wireless key to fit to this card
2. u can still let windows configure wireless for this card as well
However would like to have a clearer report about the problem
Posted on Jul 08, 2009
  • 20 Answers
SOURCE: connected a 2wire adapter, downloaded driver, but
Make sure the N router is also sending a broadcast for B/G mode, as the 2wire adapters do not support N technology. You can login to your router by typing "home" or "192.168.0.1" or "192.168.1.1" in your web browser and check the wireless settings on your Dlink to see if it supports these methods.
Posted on Jul 12, 2009
  • 20 Answers
SOURCE: 2wire 802.11 usb without 2wire gateway
http://support.2wire.com/index.php?page=download click on the adapter link for the driver and instructions. If you dont see the picture of your adapter, then click on the legacy link on the adapter page. After you install the software just use the icon on the lower right to connect to your wireless network.
Where do i find the area so I can up the strength of my modem
Hi Good Day,
In the wireless settings of the 2Wire device's user interface, there is an option to boost the gain/signal. I think you can choose 1-thru-10 and it comes defaulted at 6. Keep in mind that the 2Wire modem/router is a cheap POS and diming it out may cause heat issues and earlier failure. I say "earlier" because it WILL fail sooner or later. Yes, it's a fact. wink.png Radio interference from outside sources will affect your usable range, so while you are in the interface, change the radio channel to 3. Most wireless systems are defaultly set for "auto", 1, 6, or 11. In my experience, channel 3 has the least interference from other wireless systems and 2.4GHz cordless phones.
Apr 09, 2011 | 2wire (2701HG-B) Wireless Router
How can I boost the signal of my AT&T 2WIRE router/modem?
You can increase the range of your router but you need to purchase another wireless switch. What you have to do is buy a wireless switch and grab a computer network cord and plug it into your 2wire modem. I would advise just turning your the 2wire's wireless off. If the new router isn't strong enough you can buy directional antenna's or larger antenna's which should help with the range issue.
Unfortunately you can't purchase an antenna that you can directly attach to the 2wire.
Make sure that the switch you buy has external antennas that you can change out. If not and the range isn't strong enough then it could cause more headaches down the road.
Apr 07, 2011 | 2wire (1000-400108-001) Router
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Oct 10, 2010 | 2wire (1000-000057-000) Modem
I have an AT&&T 2701HG-B Gateway 2Wire wireless router w/DSL modem. My Mac G5 computer is attached with an ethernet cable (my computer does not have wireless capability). All this is in my home...
there is an adaptor that you can buy
it is plugged into the power socket for the house , connected to the ether net connection
you have a second plug in connection that plugs into any other power point and that runs a ethernet cable to the pc or modem
I have such a system running from the shed computer to the house computer and modem distance of 100 yards
it is called a TP-Link and is available fro Jaycar or like electronic shops
it works by using the house wiring to transmit the data signal along with the house power
Mar 23, 2017 | 2wire (1000-400108-001) Router
Not getting good signal strength frm router with wirless computer
There are signal boosters and repeaters available, but generally run in the $250 range for decent ones. What you can do is get a wireless access point installed. It requires an ethernet cable to the router to connect it, but you can put that in the house close to where you are and feed off of it.
Jun 14, 2009 | 2wire Computers & Internet
Linksys wireless adapter won't auto connect to 2Wire router
Go into the wireless adapter settings and make your connection "default" and then it should connect automatically .. and if not then look for a "connect automatically setting
May 29, 2009 | 2wire HomePortal® 1800HW Router...
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Wireless range/signal seems very weak
ok the problem is that ur using a wireless b modem
the wireless b is the shortest of the classes of wireless routers
you should go with a G or N series
this should solve ur isse
the B series is for one room operations then the signal has to go through ur home that is more resistance on the signal
you could also buy a 2wire modem /router at best buy
that covers ur whole property with ur wireless range
but u will pay the same in one router as this 2wire single unit
Apr 11, 2009 | Gateway Wireless-B Router (wbr-100)
I want to use 2 wire ATT UVerse -- BUT NOT WIRELESS
the 2wire att uverse router, does not broadcast wireless signal if there is no wireless computer connected to its network. regarding the unchecking of the ssid, it will only hide the network name of your router, but technically, if a computer will try to connect to your router, it will still "send" wireless signal to a computer within its range.
you do not have to worry about the wireless signal being sent, if nobody connects to the router via wireless cionnection.
Jan 11, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2 Wire DSL Wireless modem range expander
you might want to try to change the wireless channel 1. open your internet browser 2. type on the address bar 192.168.1.254/management or 172.168.0.1/management and press Enter 3. type your system password (modem password) 4. go to home network -> wireless 5. change your wireless channel to 9 - 10 if after changing the channel it still wont work please check for EMI (Electro Magnetic Interference) such as electric appliances, hallucinogen lamps, WIRELESS PHONES, satellite dish and or alarm systems. also make sure that you dont put your router on a carpet. usually a good distance between your router and the computer is around 5 - 20 feet with no walls between them since walls also contribute on the interference. one last note, keep your router away from water i.e. aquariums, water dispenser and the like since water contributes to the interference of the wireless signal
Feb 09, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
180 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
