Question about Whirlpool Washing Machines
My loads are not finishing and it says F-21 and the door will not open
  • elisa150 Jun 13, 2008
    thank you very much
  • 413 Answers
The drain pump has become blocked.
Remove the bottom access panel by removing 3 screws along the bottom. There you will find a pump filter that you can unscrew and remove debris. UNSCREW AND DRAIN SLOWLY as there will be lots of water to catch..
Posted on Jun 13, 2008
Blinking AC button of Honda Civic 2003
HEATING AND AIR CONDITIONING
HONDA CIVIC 2001 - 2005
How to retrieve DTC:
The heater control panel has self-diagnosis function. To run the self-diagnosis function, do the following:
1.Turn the blower fan OFF.
2.Press and hold the recirculation control switch and the rear window defogger switch down.
3.Turn the ignition switch ON (ll).
4.Release both switches. The recirculation indicator and the rear window defogger indicators come on. The recirculation indicator goes off 3 seconds later and the A/C indicator comes on, then the self-diagnosis will begin. About 10 seconds later, the self-diagnosis will finish and the A/C indicator goes off.
- If any trouble is found, the recirculation indicator blinks the diagnostic trouble code (DTC) to indicate a faulty circuit or component.
- If the system is ok, the recirculation indicator stays off.
DTC TROUBLESHOOTING INDEX
DTC (Recirculation indication blinks) Detection Item Page
7An open in the air mix control motor circuit.21 - 16
8A short in the air mix control motor circuit.21 - 16
9A problem in the air mix control linkage, door, or motor.21 - 17
10An open or short in the mode control motor circuit.21 - 18
11A problem in the mode control linkage, doors, or motor.21 -19
12A problem in the blower motor circuit.21 - 20
13A problem in the EEPROM in the heater control panel;
(THE CONTROL PANEL MUST BE REPLACED).21 - 38
14An open in the evaporator temperature sensor circuit.21 - 23
15A short in the evaporator temperature sensor circuit.21 - 24
- In case of multiple problems, the recirculation indicator will indicate only the DTC with the least number of blinks.
- In case of an intermittent failure, the heater control panel will store the DTC until the ignition is turned off.
Mar 17, 2013 | 2003 Honda Civic
Where do you load staples into a Canon imageRunner 3245i?
That would depend on the model of finisher you have attached to the machine. If it is a larger finisher attached to the side of the machine open the Sorters front cover and the inner door should have a sticker with instructions. If you have an internal finisher it can be the same concept open cover and load the staples as show on the cover. There is also another internal finisher where a gray handle is pulled to slide the finisher out and the staples load into the upper rear area of the finisher.
Mar 05, 2012 | Canon Office Equipment & Supplies
I have a kenmore HE 2plus. i am getting a f-21 error reading and door won't unlock, what is the problem and how do i get the door open?
f 21 usually means drain pump is bad. may need to check door lock an see if it reads 15 ohms across the output. if its more than 15 change the door lock
Jun 03, 2011 | Kenmore HE2 Plus Front Load Washer
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
Can not open the door after cycle is finished
i think you are talking about a front loading machine, have you waited for at least 3 mins before opening the door?
these types of washing machines locks the door in order to run. but after a cycle is finished, the door would not open right away, there is a delay on opening the door.
let me know what happened,
tnx 4 using fixya,
drcool
Sep 19, 2008 | Washing Machines
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Frigidaire Affinity Front Load Washer
You have to remove and clean the rubber around the front of door,
, Snap it back on.
disconnect AC to prevent any accidental shock.
open the bottom access panel
screws on bottom front , open the large filter and be ready for latent water to spill out , have rags ready.
clean the inside of the filter with clorox.
finally run a strong solution of clorox when you finish.
then rinse well.
leave the door open after loads finish
the door has a child lock
black dot next to lock on door , insert coin and rotate.
keeps them from closing the door.
Feb 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Open Questions:
Washing Machines Logo
20 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
