Question about Samsung HCN4727W 47" Rear Projection Television
Herringbone pattern interference comes and goes. Checked all connections, problem occurs whether on cable or dvd. This was occuring before problem with no picture or sound, just red light blinking for several moments before going out.
  • BOB BRUNSWICK Jun 29, 2008
    The red light flashes 10 times
    Master:
  • 638 Answers
Red led blinking/flashes how much times or just still without blinking after u on the tv let me know now i am waiting for your reply
Posted on Jun 18, 2008
  • hemant somaiya
    hemant somaiya Jun 18, 2008
    I have mentioned the list of no. of flashes and their solution:
    ONE Blink--- not used for the self-diagnosis
    TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
    mode then displays the 2 blink fault. Could be a short in the power supply of
    any of the circuits.
    THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
    mode then displays the 3 blink fault. This is also a problem in the power
    supply circuit, check T603 and R672.
    FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
    horizontal line then the video signal muted. Check IC1509, Q1505
    FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
    30 seconds then goes to the self-diagnosis function. Something is wrong with
    the video. Check video out, Q705, 732, 761 and other components on the C
    board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
    try turning up screen slightly.
    SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
    function immediately. Check C515 & 516 and the jungle IC, IC206.
    SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
    and the unit goes immediately into safety shutdown. Check power supply
    regulation and horizontal circuits.
    EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
    blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
    Intermittent problems ?? This is a great feature. You can also bring up
    these fault codes ON-SCREEN to see a list of the problem numbers with the
    abbreviation of the problem and the number of times this problem has
    occurred. This is slightly different than entering the service mode. To see the
    diagnostic screen, Press the following buttons:
    Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
    a screen with a list of the problems and number of times they have occurred.
    Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
    We have repeated them in parentheses in the text for the "Blinks" described
    above so you can correlate between the diagnostic screen and the blink
    codes.
    So, now that you know about these self-diagnostics, how do you use them?
    Say that you have a set with a black screen. You see that the LED is blinking
    4 times....This would tell you that you have no vertical and that is why the
    video is muted. If it was blinking 6 times, you would know that you have a
    horizontal fault.
    It's not a sure cure, but it's a little better than a poke in the eye with a sharp
    stick.
    IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is 0 corrected, so if you don't clear them, you'll be seeing "old" fault codes the
    next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns
    everything to the factory preset condition. Please don't forget to rate or accept the solution
  • 2,071 Answers
A pattern interference problems mostly comes from the supply.The solution is to reheat all the supply section,so the performance will come again.Go to a center near your place so the problem stop only reheating or resolder
Posted on Jun 17, 2008
  • 3,037 Answers
How many times is the red light blinking as this would indicate the exact problem with the tv
  • Benjamin Patri
    Benjamin Patri Jun 29, 2008
    Now is this 10 times steady or is there a pause which could make this 5 blinks, pause, 5 blinks?
Old tv plays dvds but when cable box is on or off image scrolls vertically on the screen. wondering if this is an issue that can be fixed or is symptomatic of a 15 yr old tv. thanks.
I'm not sure what you mean by "cable box is on or off". Do you mean connected? If the cable box is connected to the TV through a 300-ohm antenna input, you are probably getting a lot of interference from the workings of the cable box. Try moving the cable box away from the TV.
If the TV is connected to the cable box with a 75-ohm cable, it may not be properly grounded - try another cable.
Also try manually tuning the channel on which the cable signal comes in, usually 3 or 4. Try an alternate channel.
If the DVD player is built into the set, the signal is less subject to outside interference. If the DVD player connects to RCA jacks on the set, it is also less subject to interference.
Vertical hold problems can be caused by aging capacitors in the "sweep" circuits but usually one sees that as loss of vertical hold on the DVD signal, as well.
Good luck.
Jan 02, 2010 | Televison & Video
Tv goes off, then comes on, and volume goes to max
OMG! Verizon Fios at it again with changing boxes! Well let me tell you if you do not loose signal on a DVD using these same inputs ITS NOT YOUR TV!
Whats going on is further into Verizon system you loosing the signal from the VDSL slam outside in the pill box. This thing will need to be replaced and they are going to blame your TV until you just give up and buy a new TV only to figure out its not your TV.
1. Call them back
2. tell them to check there network
3. if that dont work tell them to check it again
4. if you have HDMI use that instead of the scart connections.
I hope you have luck with Verizon Fios there internet rules but there TV service is sub par!
Thanks
rulds2008
Jul 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I get lines running across my television (wd62525), especially noticeable when screen goes black. video noise? and it moves horizontally across the screen.
Sounds like interference or signal contamination. Does it occur on OTHER inputs? If not..then the input signal is corrupt, weak, has interference, wrong cable, or othewise defective.
Jun 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
AV inputs broken picture
The first thing I would suspect is a bad ground connection at the input jacks. Try gaining access to that board and resoldering the jack connections.
Let me know if that resolves the problem.
Thanks,
Dan
Apr 15, 2009 | Televison & Video
Toshiba 50HM66
try cable,rbg.or the yellow visual input if you still have the problem ,you may have a BAD GUN OR BULB.
Feb 05, 2009 | Toshiba 50HM66 52" Television
Red color slide on left side of 43UWX10B
Good Day,
Sounds like the TV's convergence circuit has failed:
*Call an Authorized Service Center and them give you an estimate cost of the repair, or
*Repair it your self; get KIT 10 locally or B&D Enterprises
1-800-458-6053; www.bdent.com.
Good luck, big IRISH.
Aug 05, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Good Day,
Herringbone pattern
Herringbone (and other patterns) can be caused my many faults, the obvious one the tech was looking for was a tuner/interference fault.
Another common cause is a faulty power supply.
Difficult to say without having the TV on the bench.
I'm a bit suspect about the $400 - $500 repair cost though.
Perhaps try another tech?
I doubt it's a DIY repair though.
Let's know how you get on.
Jan 20, 2008 | Sony KP-61V85 61" Rear Projection...
HCM4216W Convergence Problem
the convergence problem you had before, re- occured
Sep 25, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung HCN4727W 47" Rear Projection Television Logo
253 people viewed this question
cce772000
Level 1 Expert
