Question about Sony KP-61V85 61" Rear Projection Television
KP-61V85 Sony Rear Projection
LED light flashes 4 times and tv will not power up.
  • 1 more comment
  • supertecmike Aug 12, 2008
    standy light flashes 4 times also.sony says its the power supply board but doesnt seem like any companys carry it .can u suggest a place where i can buy one.thanks mike ... supertecmike@gmail.com
  • Anonymous Oct 01, 2008
  • Shantelb2003 Oct 16, 2008
    my daughter was watching TV during a storm and the Television turn off and hasn'tturned on since. I have the tv pulled into the wall. a few folks says the lighting sometimes go underground and hit the electronic.. I can't afford a new tv now. I'm look for solutions and am afraid I will get ripped off if I bring someone into my home to fix it with no knowledge. HELP. I miss my tub
MikeNJ1964
  • 398 Answers
SOURCE: Sony 57 in Rear Projection TV
If the picture is playing fine and you notice that the background is getting more and more red, until it is too red and the set shuts down, it could be that the red screen control is set just a bit too high. If this is the case, you can probably correct this yourself. If you are watching a perfect picture and then it suddenly flashes a very bright red, with thin red lines in the pictureand then shuts down, it usually means that the red picture tube has developed a short in it, between the cathode and heater. A good tech might be able to remove the short by arcing, but if the short persists then the red tube will have to be replaced. Either way, this is something that should only be done by a qualified tech.
Posted on Aug 27, 2007
Slinteriors
  • 8617 Answers
SOURCE: Sony Kp-fw46m31
count the flashes again carefully, as that model should only blink a maximum of 9 times, unless your getting two seperate codes. Try counting and trying to notice if it pauses a second before blinking again. then let me know what you discover.
Posted on Apr 06, 2008
SOURCE: Sony Rear projection TV problem
hi, i had the same problem today. i took a risk and opened the front bottom panel(regular star faced screws located at the side) where the speakers and buttons are located. then i unscrewed the panel located right below it. i then unplugged the wires that were connected to the bulbs(sorry i dont know the technical term for it but there should to be blue,red,and green bulbs). when i reconnected i turned it on it was fine. its been about six hours now and it's working perfect. hope this helps.
Posted on Nov 01, 2008
  • 239 Answers
SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
Posted on Mar 04, 2009
  • 4234 Answers
SOURCE: Sony kp-46wt520 rear projection tv: standby light flashes
Two things here.
1) This is a CRT based set so there is no "lamp" involved.
2) The standby light should be blinking a repeated count of blinks with a 2 second pause between counts. Please report the exact count here. This will indicate the circiut in which a problem was detected.
With the above information, we can provide you with a more detailed description of the problem as well as the likely solutions and cost.
Thanks,
Dan
Posted on Sep 18, 2009
I have a sony kp-61v85 color rear video projector and it has a red haze across the middle section of the screen like its out of focus. A tv repair man replaced 2 cv boxes and the picture got clearer and...
The tv have a problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resitors are dead.These parts on the tv convergence board,must be replaced to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Sony KP-61V85 61" Rear Projection...
My Sony KP-46WT500 TV does not turn on. Red standby light blinks and goes out.
possible bad convergence chips and the two fusses in the power suply or bad tube I need to know how many times does the stand red led flashes after it powers down
Aug 29, 2010 | Sony KP-46WT500 46" Rear Projection...
What could the reason my tv projector light up and off
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck
May 29, 2010 | Sony KP-61V85 61" Rear Projection...
My sony tv Comes on some times but then some times does not
On most of your rear projections you got GUNS and if there out of allignment or overheat you will get this error and it will need to be serviced.
Apr 22, 2009 | Sony KP-61V85 61" Rear Projection...
I have a Sony KP-61v85 projection set that wyou help meon't turn on
4 blinks is error code in KP-61V85 and shows problem as follows...
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
If you have no experience, don't put your hands in TV because TV has high voltage inside and electric shock risk involve.
Oct 12, 2008 | Sony KP-61V85 61" Rear Projection...
Sony rear projection 61in TV
Is there any incidents happen before the problem occur, like powersurge, or sudden electrical failure on your area..?
Jul 26, 2008 | Sony KP-61V85 61" Rear Projection...
Sony KP-61V85 background to HDTV Compatable Yes or No??
This TV is about 7 to 8 years old already and is not HDTV compatable.
Feb 13, 2008 | Sony KP-61V85 61" Rear Projection...
Sony kp-65xbr10w led light blinks 5 times
i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Herringbone pattern
Herringbone (and other patterns) can be caused my many faults, the obvious one the tech was looking for was a tuner/interference fault.
Another common cause is a faulty power supply.
Difficult to say without having the TV on the bench.
I'm a bit suspect about the $400 - $500 repair cost though.
Perhaps try another tech?
I doubt it's a DIY repair though.
Let's know how you get on.
Jan 20, 2008 | Sony KP-61V85 61" Rear Projection...
Sony KP-61V85 61" Rear Projection Television Logo
52 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
