Question about Freezers
Freezer not keeping things frozen
I have a refrigerator with a freezer on top and I noticed a few months ago that ice cream was not staying really frozen so I tried putting less stuff in the freezer and turning up the temperature and that seemed to help for a short period of time. Over the past week it seems to have gotten worse but it was still freezing ice cubes and frozen lunches were staying frozen etc. I pulled it out this past weekend, unplugged it and vacuumed the coils and cleaned under and behind it. And it has gotten worse since then. My frozen veggies and bread and frozen meals are all defrosted and ice cubes are starting to defrost and new ones are not freezing. Things in the fridge seem to be staying cold. Do I need a new refrigerator?
  • 525 Answers
Hi Jody,
The only thing you give me that would allow me to solve this issue, is based on the fact that the freezer is getting warmer, and fresh food section is staying cold. So, knowing nothing more than that, I must sadly say that you need a new refrigerator to solve this issue 100%, as it sounds like you have a failing compressor, or a slow leak in the sealed system. Both scenarios are terminal.
Thank you for contacting me at Fixya.com
Dave E. (Illeagle)
Posted on Jun 13, 2008
Freezer is not even keeping ice cream from melting..and the 2 slots at the top in the back by the top shelf?? Are filled with IVE
Do an old fashioned dethaw of your icemaker. Remove food in compartment, unplug or turn off freezer. Leave doors closed, and get a thick towel and a pot of boiling water. Place the towel under the pot, close the door, and let the heat from the pot warm up that frozen freezer vent. That will clear the ice so the fan can draw cold air out into the freezer
Aug 01, 2014 | Samsung RS261MDPN - 26 cu. ft. Side by...
Freezer will not shut off some things frozen, bread and ice cream soft
Have you checked that the door is closing ok and that the door seals are meeting the door frame all round?
Do the things that freeze sit at the top of the freezer? if so it could be
the coolant gas has slowly leaked out. A good indication this has happened is that the bottom of the freezer is a lot warmer than the top. To repair a serviceman will first cut the coolant pipe and drain (and capture) the existing gas and then recharge, re-pressurise and seal.
Dec 28, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer keeps beepimg
if the temp. in the refrigerator side is 20f, its to low, set the ref. to 40f and freezer to 0f.
Sep 23, 2012 | Liebherr CI1651 30" Built-in...
Our sub zero seems to defrost in cycles. Not sure why ice cream melts in there while other meats remain frozen. Is this an expensive problem?
The defrost may be lasting too long....and ice cream is always the first thing to melt... you need at least 10 F to keep ice cream hard...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Sub-Zero Freezers
2 months ago or so, found puddle of water in front of our freezer; about 1 month ago ice cream in freezer became soft. High temp alarm went off a week ago--I've checked the temperature intermittenly and...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 22, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 | Freezers
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Meat is frozen but ice cream is soft
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
heatman101
Aug 31, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
388 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
