Question about KitchenAid KGST307 Gas Kitchen Range
Broken inner glass on kitchaid range how to remove the door
Kitchenaid range how do you remove door to replace the glass the inner glass
  • pleader Apr 11, 2009
    Door: broken interior glass and also a slipping seal falling down behind the exterior glass. Need instructions for disasembly and fixing.
  • 426 Answers
Screws near the hinge, make sure to get oven/tempered glass sometimes the screws are located in the crack between the oven and door on the bottom
Posted on Jun 13, 2008
Tip
Replacing the inner door glass.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
on Apr 07, 2009 | KitchenAid KGST307 Gas Kitchen Range
Inner door glass replacement
open door fully, look down by hinges where enter unit, pull those metal tabs back that lock the door in place, close door to broil position 3/4 way closed and lift up, which should get the door off the unit.. once removed you would have to get acess inside that door by a combination on removing outer sccrews and hing screws and also seperating those glasses.....be careful to remeber how everything goes back i know of some techs that run into problems reassemblin those doors.. hope this helps,, some local service companies often charge a smaller in shop service call for small items like that if thats avaialable in your area,, hope this helps
Feb 07, 2010 | KitchenAid KESC307 Electric Kitchen Range
Inside oven door glass broken Can I replace broken inner oven glass myself? I broke it today and need some help.
I would guess that you could not. It is a safety glass and has a special gasket material. Although you may be able to buy the door as cheap or cheaper than just the glass plus the install. Hope this helps. Have a great day.
Apr 17, 2009 | KitchenAid KGSC308LSS Gas Kitchen Range
3 Remove the inner screws. Keep all set of screws ordered, and take note of the order you remove them. You will follow reverse order in reassembly.
Kitchenaide gas range inner door part number 9781721 is cracked.
Mar 24, 2009 | KitchenAid KGST307 Gas Kitchen Range
The interior glass on the door shattered last night when I had the broiler on. Can the glass be replaced or do I need to replace the entire door. Kitchenaid Superba Model # KERC607HBS1 Serial #IMJ4544460
The inner glass is replaceable. The door will have to be removed from the range (see your user manual) and disassembled. Most repair shops can do the replacement for you at a nominal charge if you take the door in to them.
Jul 28, 2008 | KitchenAid Kitchen Ranges
How to replace inside glass on KitchenAid KERC608 Type 30P Range
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the lock position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
Jun 16, 2008 | KitchenAid Kitchen Ranges
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KGST307 Gas Kitchen Range Logo
642 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
