Question about Epson Stylus CX5000 InkJet Photo Printer
Catridge won't go to right position
I had problem with Epson Stylus CX5000 InkJet pronter and I got a replacement printer. When I powered the pronter catridge box will always stops at ink replacement postion. Even when I load new catridges or even I f remove the catrdges always goes to replacement postion. Never goes to expended ink mark or to the extreme right end. Ink light and power light always blinks. When I called Epson they send me new one still it has the same problem. Am I missing some thing
  • difpa Jun 13, 2008
    Hi
    Thanks for replying. Actually as I said in my post the catridge never stops at OUT OF INK which is also called expended ink mark. The print heads always stops at REPLACEMENT POSITION either I put new catridges or even if the catridges are removed
    Scholar:
  • 40 Answers
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Posted on Jun 13, 2008
EPSON STYLUS CX5000 OWNERS MANUAL
Hi
You was after a manual for a cx5000 printer I put one on my website for you can download from my link here it in a PDF file format so if you not got a reader for it you can download one free form the links.
Adobe Reader Links = http://www.adobe.com/products/reader/
Your Manual = http://www.4all2sell.com/pdf/EPSON-STYLUS-CX5000.pdf
All The Best: Pineworks
Jan 26, 2010 | Epson Stylus C86 InkJet Printer
DOWN LOAD MY PRINTER
You can download the contents of the printer's CD from Epson's website at the following link:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=72185&prodoid=63059191&infoType=Downloads&platform=All
May 15, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Need instructions for epson stylus dx5050
Here is guide for CX5000, that is same model as DX5000
User's Guide
Below you also find assembly instructions:
EPSON STYLUS CX5000 / DX5000 / DX5050
Jan 30, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Epson stylus cx5000
Hi-
Try reseating the blackcartridge, take it out and reinstall it. if it fails then have the cartridge change it might be damaged for some reason( bad cartridge). call 562-276-1300 for replacement.
Hope this helps
Sep 01, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus cx5000 - no power
If you have already tried different, USB cable, different power cable, different USB port you may even go as far as trying it on a different computer and if for any unfortunate circumstance you're still experiencing the same thing chance are its already a broken fuse or broken board on printer. Unfortunately this is a non-user replaceable part. I suggest that you contact Epson support if you printer is still under warranty from the date of purchase they may send you a replacement (brand new or refurbished) otherwise they'll be referring you to a service center in you area.
Apr 14, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus  CX5000 InkJet Photo Printer Logo
119 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
