Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
Automatically Resets itself every 15 seconds
So basically a few days ago my Linksys router stopped broadcasting my cable modem's internet connection.  This has happened fairly frequently so I just reset the modem.  Well this time it still didn't work, and I knew it was most likely a router issue because I could plug the cable modem into the computer and get the internet fine.
Ever since resetting the router, it hasn't worked at all.  I can briefly connect to it for about 10 seconds, but then, judging by the lights on the front of the router, it restarts itself.  It flashes all the lights, then they all go out, then the power button flashes, then the wireless button flashes, they both stay lit for about 10 seconds, and then it starts over again.
This is very frustrating.  I'm convinced that if I can just get the router stable, I will be able to upgrade the firmware, but as of now I can't effectively connect to it for any meaningful period of time.
Thanks for the help.
  • 2 more comments
  • ohfosho15 Jun 12, 2008
    I think it's just broken. Now all the lights go on and off intermittantly. I'm going to buy a new router (not linksys) today.
    Shukran.
  • aztxok Nov 07, 2008
    My router is doing the same thing. reseting every 10-15 seconds. All the lights will flash. I only have one port in use. If I connect the PC to the modem directly, it works fine, no dropped internet.
  • Anonymous Dec 15, 2008
    Hi i have the same problem with my linksys 200 as the others . I will just disconnect and all the light will flash. This must be a problem with the router and the signal. This has never happen before . I will have to purchase something else.
  • Anonymous Dec 27, 2008
    my router resets frequently when my desktop and laptop are online at the same time.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
Check the reset buton it may not put properly adjusted, so it may be put the evice abck to reset. if this is okay, try and put off the device disconnect all cables that link to it. put it on without connecting it, then see if it is rest it self, it it doesn't then plug the cable one by one. this should help. good luck
Posted on Jun 12, 2008
    Sniper:
  • 87 Answers
the wall plug type power supply (made in China) may be likely bad.
This actually is a switch mode power supply very unlike the old and usual linear power supplies.
It is common the capacitors used in this supply are under rated and do not last very long.
The problem usually seen with dim LED lights on the unit, limited range and intermittent operation.
Try to find a replacement power supply with perhaps higher current rating.
Good luck
Posted on Jan 10, 2009
How to setup
Connect your ethernet cable from your cabe modem to the port on the left
When first setting this up hardwire your pc to the runner utilizing one of the 4 ports on the right.
After you make the connections from Cable modem to Router to PC.
  1. Unplug both your modem and the wireless router
  2. Keep unplugged for 30 seconds then plug your modem back in
  3. Count an additional 20 seconds and then plug your router in
Wait a few minutes for the modem and the router to startup and begin communicating.
Finally click on your browser and test your connection... You should be in business,
Now that your internet is being broadcasted unsecurely, It would be in your best interest to secure it.
Follow these instructions and you should be in good shape
Wireless Securuty Linksys Setup
Feb 18, 2011 | Linksys Wireless-G WRT54GS Router...
Tip
Wireless Network Password - Linksys
If you are unable to connect your laptop wireless to your Linksys wireless access point/router, the easiest and fastest way to get going is to reset your router to the factory defaults. This will make your router work like the day you bought it.
There are 2 steps involved Reset your router, Setup/Secure a new router
Reset your router:
First
  • Unplug your DSL/Cable modem from power (not your access point/router) Leave this unplugged for now
Second
  • On the rear of your Linksys router you will find a small RESET button
  • With the power still on the router, Press and hold (with a pin/pen tip) the RESET button for 30 seconds.
  • Release the RESET button a wait 15 seconds for the router to reboot
almost done....
  • Unplug your Linksys router from power
  • Plug your DSL/Cable modem back in to power
  • Wait 1 minute for the modem to boot up
  • Be sure the ethernet (cat5) cable from your modem is securely plugged into the WAN port on the back of your Linksys router. This is usually labeled WAN or Internet above the jack
  • Plug your Linksys router back into power.
You will now be able to connect to the internet with your wireless device. I would advise that you follow the next steps in securing your wireless network.
Log into your router
  • Type 192.168.1.1 into your web browser and hit enter
  • In the login fields (case sensitive):
  • Username: leave_this_blank
  • Password: admin
  • Click OK
Once in the web interface for your router
  • Click Wireless tab - Basic Wireless Settings
  • Find the Wireless Network Name (SSID) field
  • change this to your new network name (this is the name you will see when you connect through your wireless device)
  • Find the Wireless Channel field
  • Change this from 6 (default) to 1 or 11
Magoo
on Mar 12, 2011 | Linksys Wireless-G WRT54G Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
My linksys wrt54GC stops working when connect internet cable
There might be a reason that the default gateway of your router and the internet are same.So first connect your router to any one of the computer and open the router page by typing 192.168.1.1 (username should be left blank and password-admin).Then on the basic setup page change the Local IP address to 10.10.10.1,scroll down and click save settings.Now power off your router and connect internet cable to internet port of the router.Switch on the power of router and now try to go online. If you are unable to go online then connect your computer directly to the modem and download the new firmware from www.linksys.com/support and connect your computer then to the router,upgrade the firmware of the router and try to go online by connecting internet cable.
Jun 05, 2009 | Linksys (WRT54GC) Router
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Can Connect to internet via cable modem, but cannot connect from Cable Modem to LinkSys WRT54G router to PC to Internet ?
1. Make sure your cable modem is connected to the Internet port of the router.
2. Your computer should connected to one of the 4 ports at the back of the router.
3. Check the lights that are lit. Make sure the you have power(steady green), Internet, WLAN and Ethernet port light.
4. Press and hold the reset button on the router for 15 seconds.
5. After 15 seconds, release the reset on the router and turn it off.
6. Turn the cable modem off, too.
7. Wait for a minute. Turn the modem ON first. Wait for the lights on the modem to be ready.
8. Turn on the router. Make sure you have good lights on the router.
9. Check for Internet connectivity.
Nov 08, 2008 | Computers & Internet
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
My son installed this new router that I paid for just about a week ago. It is the Linksys and there are 4 computers including this one that is mine connectng to it. The router fails every few days and my...
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 20, 2008 | Linksys Wireless-G WRT54G Router
Internet connection problems using the BEFW11S4
If you are having problems connecting to the Internet, follow the following steps: 1. Internet service: Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. This will narrow the issue down to either the service, or the router. 2. Network cables: Verify that the network cables that connect the network together are plugged into the current ports as they should (modem into the WAN/Internet port, computers into 1, 2, 3, or 4). Also try to change some or all of the network cables that attach to devices coming from the BEFW11S4. You may have bad cables. 3. Router configuration: Your router may not be configured to use your Internet service properly. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. Note: this program must be executed on the main computer when plugged directly into the providers modem unit and able to get on the Internet 4. Manual configuration: If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online, visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 5. Router firmware: Upgrade your router to the latest firmware version. Please go to http://www.linksys.com/download to download the latest version of firmware for your product. After the upgrade, be sure to reset the router, by holding in the router?s reset button for 30 seconds and reconfiguring it for use with your service (Step 3 or Step 4). 6. Malfunctioning equipment: You may have a faulty network adapter, or a bad router. Please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
250 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
