Question about Hitachi 43FWX20B 43" Rear Projection Television
Reply on hitachi
Why do you think it something that we could not fix ourselves?
    President:
  • 2,712 Answers
Because as I mentioned, it can be complicated if you have no prior experience and dangerous as well. But if you do have experience in electronics and soldering, then try a DIY by all means!
I always give that statement as a word of caution to all similar queries. Better safe than sorry :)
Posted on Jun 12, 2008
We have a Danby DDR601 and it stopped running. My husband thinks it could be the compressor? Is taht something we could fix ourselves?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 22, 2011 | Danby DDR601 Dehumidifier
Hi Gurus - we have a Whirpool Gold Quiet Partner III whose control panel is dead. Pressing Air Dry doesn't seem to work. Looks ok at the fuse box. Should we get an electrician in, or an appliance...
On a lot of whirlpool models their is a fuse on the control board that is wired directly to the board if it goes out the machine will be dead exactly as your experiencing,i would call a appliance tech and if it something ya think ya can repair,reply back with model# and ill give ya part #
Hope this helped and if it did please give me 4 thumbs up
Gene
Jul 28, 2011 | Dishwashers
Shadowing and blurriness
needs a convergence board repair, not too hard to fix if you are handy with a soldering iron.
get the 2 convergence chips for this model @ partsstore.com
Mar 19, 2009 | Hitachi 50FX30B 50" Rear Projection...
Hitachi TV HELP!
Hi, magic focus button is behind a small door on the front of the set just below the screen, I don`t think it is going to help I believe your convergence IC`s have failed,try pushing it once and let it finish, if still 3d image you need to call a tv tech, good luck, video-tek
Feb 09, 2009 | Hitachi Televison & Video
Hitachi projection 53" screen color off
Since this is a CRT based projection set, there is no "lamp" involved. Does the picture look like 3-D? If so, the problem is likely to be a convergence problem. There should be 1 or 2 convergence ICs marked STK392-110 inside attached to a heatsink. If you can solder, try resoldering the pins on those ICs. If that fails to resolve the problem, replace them.
Keep us posted.
Dan
Jul 14, 2008 | Hitachi 53UDX10B 53" Rear Projection...
SuperScan Plasma TV SSH2442
here is one thing it could be cracked solder on the ribbon cables going to the screen there along the bottom of the TV if the bars line up with a connector it is probably your problem i will try to post the link to a hole writeup on it
Feb 07, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 53UWX10B Projection TV - Color Separation
Common problem on all rear projection TV's...............
Somewhat difficult,requires chassis pull and solder in new parts.
Part # stk392-110 subs to upgrade stk394-160E part # CZ 01341
Dec 12, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Problems with the DVD of Hitachi 46W500 46 in. TV/DVD Combo
These units have prepritary DVD units and cost anywhere from $30 - $200 for a replacement. If the cleaning disc didnt work more than likely its REALLY dirty or the pickup itself has malfunctioned.
Sep 15, 2007 | Hitachi 46W500 46 in. TV/DVD Combo
Anyone know
Usually this occurs when the Convergence ICs go bad along with some chemical fuses mounted on the deflection board. E994 usually blows along with the Horizontal out transistor going bad. This transistor, I believe is Q777 that usually goes bad. The fuses are either tiny little yellow fuse with a red band or green with a yellow band depending on your model number
Jul 08, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
