Question about Samsung Televison & Video
Trouble connecting DVD
Hello!
I have been trying to connect my Toshiba DVD player to my Samsung TV and have had no luck! Even though I have followed the instructions, it gives me a "no signal" message.
Help!
  • didier_r14 Dec 30, 2008
    I have the same probs but instead of a Toshiba, it's a LG , the problem is that it does not appear on the component 1 or 2 what i would like is that both Satellite tv and DVD are connected with the tv , i have put Satellite tv on AV and DVD on component even this it does not works. please help me.
    Thank U.
  • mike ireland May 11, 2010
    what are the model no of both units
NEWER TV SETS REQUIRE THE RIGHT CABLES, USE S-VIDEO OR AN HDMI CABLE WILL SOLVE ANY PROBLEM
ALSO SOME T.V SETS ARE JUST LIKE THE PLUG AND PLAY YOU HAVE WITH COMPUTERS, ONCE THE RIGHT CABLE IS CONNECTED AND YOU CHANG TV INPUT FROM YOUR REMOTE IT WILL PICK UP YOUR DVD
Posted on Jan 21, 2009
Only sound and No picture in Toshiba DVD/VCR combo
maybe your connections are wrong.
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
Good luck.
Apr 28, 2010 | Toshiba SD-V392 DVD Player/VCR
Need to connect a toshiba 5 disc sd-615 through a samsung vcr
Please refer the page # 10 of 30 of the DVD Player for the correct connection.
To download the Manual follow this link:
http://www.tacp.toshiba.com/tacpassets-images/models/sd-k615/docs/sd-k615_om_e.pdf
OR
http://www.manualnguide.com/manual-get/13955/
I also suggest that you also refer the Manual of the Samsung VCR to connect it correctly.
Good Luck!!!!!!!!!!!!!!!!!!!!!!!
Sep 05, 2009 | Televison & Video
Just got a samsung H1080 DVD player playing black and white only
The component connection should have one red, one green, and one blue connector that will connect to the back of your player and the back of your television. Then there should also be another red and a white connector that should run from the AUDIO L & R OUT of your player to the AUDIO L & R IN beside the Component IN connections on your TV. The yellow cord would normally be running from the VIDEO OUT on the back of your player to one of the VIDEO IN connections of your TV.
Aug 12, 2009 | Samsung DVD-H1080 DVD Player
Connecting VCR to TV
Oh man dont shoot your stuff instead use your remote and go to your menu and select your input. You tv is looking at your coaxial input but you can select which input you want. 1, 2 front back whatever you need. channell 3 or 4 has nothing to do with connecting up your dvd if you connect and choose the front connection in your menu.
Oct 21, 2008 | Televison & Video
If you have the original remote controller, try to switch inputs. It must be on the f-connection ( coaxial) at the moment. You need to switch it to RCA or S-Video Inputs.
Aug 30, 2008 | Toshiba 27DF46 27" TV
How to access AV channel on Toshiba TV model 2125RA
some sets auto-go av when you plug a rca jackin the set, others have a switch in front or back , others you might set your channel to 00 or 99 or 100 forget and work different , I the owners manual of course would tell you. but I assume u dont have it . try hooking it and letting the dvd run now find it using the remote.
good luck.
Feb 23, 2008 | Televison & Video
Compatibility Issue with HDMI Switch?
anytime your talking about a switch your talking about a temporary connection. The issue with using a switch is that for HDMI you want best quality and you will not get that using a temporary connection. The unit may be recognizing a weaker signal and turning the port off. However since the output on that particular unit is 1080i you should be fine using composite, just get a nicer monster set.
Dec 26, 2007 | Samsung DVD-R135
Having trouble setting up dvd/vcr
Slide down the cover on remote control.On the bottom right side you'll see a little switch(usually is cowered with the warning white little sticker).Slide that switch to DVD1(or DVD2 if somebody got different setting).Power up DVD/VCR combo press system menu botton,go to settings,change to DVD3(factory default)and there you go.Good luck.
Rich
Dec 25, 2007 | Televison & Video
Audio, but No video when connecting DVD player to TV
Try checking the AV cable. Just interchange the Audio and Video cables, and if now you get video, and no audio, problem is faulty cables. Replace.
Apr 15, 2007 | Toshiba CZ27T31 27" TV
Televison & Video Logo
195 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
