Back to:
Tags:
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Re-assembly after belt replacement
posted by vacuum break on Jun 12, 2008
I can't seem to figure out how the red clip goes back on after the black retainer arm. I found instructions but the drawings are very vague and unclear. does anyone have real color photos of this area?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jun 15, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Try clicking the handle down first, the black arms that are in the way of the red retaining plate will receed when handle goes down allowing you to snap the retaining piece right in...no problem!
Hope this helps or you have already figured it out!!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on re-assembly after belt replacement:
I don't want to Accept this solution
Solution #2
posted on Jun 12, 2008
Not Rated (0)
ol_lonely
Rank:Guru Guru
Rating: 87%, 40 votes
The small red clip has a tab on it to hold in place while putting back on. put the screw in the hole in clip and use tab to guide into place. if there is no tab, then you need to obtain a new set of clips, very inexpensive. the laege red clip is easy to put on since it goes into a groove and can't go on backward.
Thank You!
Can you Help with these Vacuums problems?
Bissell 7901-1 ProHeat Scotchgard Upright...
1 side of my brush will not stay up. Could this be a...
After having to change a belt I decided to do a really...
Seems to be the same problem as alot of other folks. The...
I have replaced the pump in my unit. I cannot remember how...
bissel proheat mod# 7901-1 07124c
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
