Mymusix mp3 PD 6070 1gb version
When I turn it on, it shows "MyMusix", and then nothing.
When I connect it to my computer (WinXP) it show "New hardware found / MTP Device" and then nothing.
I had downloaded the update 2.1 on the official website, but it doesn't work.
Can you help me please? I don't know what to do now
  • Anonymous Jun 21, 2008
    mp3 pd 6070 will not turn on
  • sunsetcjc Aug 21, 2008
    won't turn on
  • 8,596 Answers
Only follow the advice I am about to give if you have read the company's website/manual and done troubleshooting with them first. This is complicated and is more of a last resort sort of thing:
Unplug the mp3 player, uninstall the MTP Device on your computer, and then replug the Mp3 player. Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> Device Manager --> click on plus sign next to Windows Devices (wording varies from computer to computer - click on every plus sign if you can't find it) --> double-click on MTP Device --> Uninstall
-Tha Mp3 Doctor
Posted on Jun 12, 2008
2 Suggested Answers
SOURCE: MyMusix PD-6070 MP3 Player don't work
My mp3 player wont turn on
This might be a tricky one to solve - may take more than one method.
Start by resetting the player. Then replugging it into the computer.
If it still fails:
Uninstall the PD-6030 via device manager. The PD-6030 needs to plugged in to do this. Go to Start, Control Panel and select 'Performance an Maintenance'. Then Select 'System'. Then select the 'Hardware Tab' and select 'Device Manager'. Then find a device called 'Portable Devices' or 'Windows Portable Device'. Then select the + sign next to the device and right click the 'Audio Player'. Select 'Uninstall'. Click 'OK' when it asks you if it is OK to uninstall. Then select 'Action' at the top of the Window and select 'Scan for hardware changes'. Then once it re-installs the driver, see it operates
correctly. Also, performing a firmware recovery procedure can work to make your computer recognize the PD-6030. Please follow the set of instructions titled, "Q: How to recover my player's firmware?".
The firmware upgrade can be found at www.mymusix.com
-Tha Mp3 Doctor
Jun 13, 2008 | MyMusix PD-6030 MP3 Player
Won't charge
try connecting it to the usb without the cord
May 09, 2008 | MyMusix PD-6070 MP3 Player
Delete music from pd-6070
The MyMusix device software is buggy and prone to break downs from time to time. Reformatting the device usually fixes these problems. The best way to reformat is to use the manufactures firmware update process.
Go to the MyMusix.com website and download and install the firmware upgrade for the PD-6070 player using the download drop-down menu.
Back up all of the songs on your player to your computer hard drive.
Carefully read (or better yet print for future reference) the PD-6070 FAQ instructions for running the firmware upgrade, especially the drop down to select the US version of the firmware.
Run the firmware upgrade. It will reformat your device and restore it to it's original capacity.
May 06, 2008 | MyMusix PD-6070 MP3 Player
MP3 PLAYER JUST SHOW MYMUSIX, WON'T GO TO MENU
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Apr 23, 2008 | MyMusix PD-6030 MP3 Player
Feb 26, 2008 | Audio Players & Recorders
Mymusix PD-6070 MP3 PLAYER WONT WORK
http://mymusix.mmvoice.com/products/audio/PD-6070/software.html
The MTP detection problem software download fixed it for me. I don't know why this download isn't mentioned on their FAQ on the site.
Jan 04, 2008 | MyMusix PD-6070 MP3 Player
Unit Won't Turn On
I found some directions on mymusix.com. Basically, it recharges through the USB connection so plug it into the computer. Then wait for the little battery picture to be full to indicate the battery is charged. I am waiting...
If you don't even get a picture of a battery, you have a bigger problem. Check the website for adding firmware (under FAQs, under the 6070) and if that doesn't work, you might need to take it back to Radioshack and tell them. They seem to be good about taking things back..I think the one I bought is a return since it already has music on it. Not sure if that is good or bad.
Dec 25, 2007 | MyMusix PD-6070 MP3 Player
Mymusix pd-6030 player
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Nov 29, 2007 | MyMusix PD-6030 MP3 Player
Mymusix (PD 135-02) 1GB MP3 player files not recognized by my computer
MyMusix MP3 Player PD-6110 doesn't show up on my computer. I'm using Windows 98SE and downloaded the driver I needed but I still can't find this device.
Nov 22, 2007 | MyMusix PD-135-02 MP3 Player
Dead MP3 Player?
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Nov 13, 2007 | MyMusix PD-6030 MP3 Player
76 people viewed this question
 Grubhead
Grubhead
