Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
Grates for gas grill
I had an old Kenmore gas grill given to me. I restored it, everything is great except for one thing. I can't get the #@^%!! grates back in. It has the main one and then two above that one. Help!!!
  • 4 Answers
Look on the Appliance Factory Parts (www.appliancefactoryparts.com) website for the specs for your grill. The technical drawings may help you figure out what went wrong. If that fails, you can always get new grills which will fit from them. (800) 955-7075.
Posted on Jun 19, 2008
How to fix a rusted grate
Clean them with CLR or a wire brush , sand blast them ,.
Dec 15, 2012 | Weber Q Grill
I am looking for the top and bottom grills for the patio classic 6000 grill . thanks for the help.
Check with Lowe's. They carry a large number of generic grates for gas and charcoal grills. However you must have the dimensions of the grates or take the old ones with you to the store to match them up.
Jan 27, 2011 | Patio Classic 2000 Series Grill
How do I clean my grill?
Use a grill brush, if you have porcelain grates then use brush for porcelain. If you have cast the wire brush one works great. Don't use wire brush on porcelain it will scrap it off.
Mar 03, 2010 | Weber Genesis Silver C Grill
I am looking for the little rubber feet for the grates of my Kenmore gas range Model 36275980890
Rubber feet for kenmore gas oven range, These are rubber plugs that fit into the bottom of the grate and are shaped like upside down mushrooms. There are 4 of them for each grill. The part number is wb2k101 from sears (special order). Cost is about $5 for a bag of 4 rubber feet.
Jun 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Flames are shooting out of the grill area by the front knobs
I have had this happen & it is because your tube is clogged with a spiders web, I can about guarentee it; this happened to me 2 years in a row. Simply turn off the propane & disconnect the tank.....take off the grill grate & flame hood ....remove the tube & look inside it & see if its clogged....clean & put it back & everything should be fine.
Jun 01, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Re: hi
How old is the grill?
When was the last time you cleaned the grill?
Is it Liquid Propane or Nat. Gas?
Apr 19, 2008 | Ducane 30400040 Stainless Steel Grill
Kenmore gas grill 141-16228
I would love to know the answer myself, I can't figure it out now that I have the grill half taken apart.
Jan 14, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
KENMORE Gas Grill 141-152210 Kenmore 437 sq. in cooking will only heat to 250 degrees
sudsy, this exact same thing would happen to me every time I changed a tank. I know it's nothing to do with the grill itself. I would have to seat and reseat the regulator hose to the tank a couple of times before it would start heating normally. Your model has 3 burners and I suspect that the flame is real low on each one even on the high setting. Try connecting and disconnecting the tank a couple of times and see if it comes to life. If worse comes to worse you can order a new regulator hose. Part number P3632L. Catriver..post back.
Apr 03, 2007 | Kenmore 437 sq. in. Cooking Area Gas Grill...
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
67 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
