Question about Yamaha HTR-6030 Receiver
Cracking when i turn my surround up loud, the front right speaker cracks pretty bad, so i can't turn it up all the way and get the full experience. any suggestions on how to get the cracking to stop. i even got rid of the wires they give you and bought some high quality speaker wire, but the front right is cracking bad when turned up. and its only the front right. replaced the high quality wire with another piece i cut and everything.wire, and checked the hookups and everything looks good.
I don't know if this is a solution but I was getting the same thing and adjusted the dynamic range to min and it seemed to get rid of the crackling sound. Not sure why that works but it does.
Posted on Mar 24, 2009
Bose cinemate speaker system suddenly gets very loud why?
If the unit is around 5-6 years old or less, you have a bad Rotary Encoder. It is an input to the microprocessor IC(a computer within your Bose). If you would like to inquire about repairing your Bose, please visit me at my website, audioserviceclinic.com. You may contact me directly from the site.
Jul 19, 2014 | Bose CineMate GS Series II digital home...
When i turn the volume up to(17-20) my sound cuts out and my speakers make a cracklin noise.i have bought new speakers and rechecked all wires.my speakers are rated at 50 watts rms and my stereo pumps out...
It seems you needs more power to maintain the level of good sound.Maybe the maximum volume is 30 - then the mininum is 15 and you can't hear any cracking sound. If you exceed 15 the minimum, as you said starting 17 - 20 you hear crackling sound .Then you reach ,what they called the "cliping level"so much distortion and crackling sound,your stereo too small to accomodate .You must add a power amplifier so crackling will gone and to fit your listening pressure...
Hope it may help you;
Regards,
VOTIT
Sep 21, 2008 | Car Audio & Video
Cracking noise of Lexicon MC12HD
replace your hdmi cable between tv and preamp...lemme know if it works.
Feb 17, 2014 | Lexicon Audio Players & Recorders
I hooked up my newly purchased Sony BDP-S560 with HDMI to my projector for video, optical cable to my Yamaha RX-V750 for audio. I tried several audio setting with the BDP-S560. However,I cannot get any...
It sounds like the BDP unit is set to downmix PCM to the Optical Digital Audio output (the default). You need to change it to something like Dolby Digital. Crack the manual and look at all the digital audio settings you need to choose.
Aug 04, 2010 | Sony STR-DG510 Receiver
Speakers are thumping and cracking when powered up...why?
you are better off setting your deck speakers amp to a high pass filter setting on the amp. Adjust gains to increase desired bass and clarity. Turn off loud button if you have one, that will distort your deck speakers.
Feb 13, 2009 | Power Acoustik PTID-8960 Car Video Player
Horrible cracking souns through surrounds with TX DS 787
If I remember correctly there was a problem with the DSP board that required a chip replacement to resolve this problem. I replaced many of these in the past. The IC involved is a surface mounted IC that is not the easiest to replace. This is not a home repair. I'll double check my notes on this, but once replaced, you should not have the problem again. The problem was an incompatability of the initial manufacturer's IC with the design (or something like that). The IC runs about $25-$40. I'll post additional details when I get the notes.
Dan
Jan 30, 2009 | Onkyo TX-DS787 Receiver
LogitechX540 speakers hooked them up to our PC makes raspy sound
you might try putting in a new sound card to see if that dosent help. it should take care of the problem
Jan 11, 2009 | Logitech X-540 Multimedia Surround Sound...
Pioneer VSX-D85OS very loud static through speakers.
Its over heating no cheap fix. But wait if u buy an eternal fan n place it on top or behind it will do the trick. Try blowing on top when static happens n sound comes back on.
Nov 07, 2008 | Pioneer VSX-D509S Receiver
Polk Audio RC55i In-Wall Surround Speakers (can't hear whispers)
I'd make sure that the receiver surround mode is set for one of the digital settings, such as Dolby Digital or DTS, and make sure that you have the center channel level adjusted to a level similar to the other two front channel speakers. I've seen/heard this happening when using dolby digital material & having surround set on something like 'hall' or 'stadium' or dolby surround, where only 4 channels are used & the amp has to 'mix' sounds to the left & right front speakers. It'll often sound like the actors on screen are talking out of the bottom of a barrel, with a hollow & tinny character to the voices.
Jan 07, 2008 | Polk Audio RC55i Main / Stereo Speaker
Yamaha HTR-6030 Receiver Logo
140 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
