Fixed the coupling on my kenmore. Can't attach the motor back!
Ok, I put changed the coupling on my kenmore washer. But how do you reclamp the motor back in place. The 2 mounting clamps are not easy to clamp in place. Is there a trick to this. Thx
  • 413 Answers
First make sure the coupler has engaged properly. Then lower the motor enough to engage the bottom clamp. Then with your thumb on the motor shaft and other fingers on the top of the motor, lift the motor and engage the top clamp.
Posted on Jun 13, 2008
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
Just replaced a broken drive coupling on my Kenmore washer
the wigwag is bad, which has to be replaced,, you need to find out what caused the drive coupling to fail in the first place & fix that problem or else you will have the same problem again..
Aug 01, 2010 | Kenmore Washing Machines
I just changed the coupling on a kenmore series 80 washer. When the new coupling was in place(before putting the clips back on) the motor and gear box spindle (axle) turned freely by hand as I held...
If the holes and plastic prongs on the coupler aren't aligned correctly the rubber piece can be deformed.
I'd pull the pump and motor and make sure that the holes and prongs are installed correctly.
You shouldn't need any pressure at all to get the motor back on and the clips hooked up.
Make sure that the flat pieces on the plastic parts are on the motor and transmission shafts
Jan 08, 2010 | Kenmore 24902 Top Load Washer
I have a kenmore top load washer that stops & starts during wash agitation cycle and then sits with water & doen't go to spin cycle
check the lid switch,open the lid and use a pen or screw driver and touch the lid switch and listen for a click,if it doesn't click change the lid switch,if that's ok check the coupling,take off the front of the washer,take off the pump and then take out the two screws on the clamps that hold the motor in place,when you remove the motor you'll see the coupling,
Oct 31, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore Heavy Duty 70 Series Extra Capacity Plus Washer and it won't spin or agitate, but it does empty water out. How can it be fixed? We can't even find a diagram of it or match the model number...
If this is a Kenmore Top Loader washing machine, it sounds like you have a broken motor coupling. The washer filling and draining, but no agitation and spin are common symptoms with this problem. There may also be a rattling or whirring sound as the drive motor attempts to engage.
NOTE: If the washer drains, the drive motor is working. This drain pump on this washer is driven by the drive motor.
The motor coupling is located between the back side of the drive motor and the gearcase (transmission). The coupling is used in place of a drive belt, which is why this type of washer is referred to as a "direct drive". The following link explains how to access and replace the motor coupling:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The part number is included with the link and can be purchased at appliancepartspros.com for about $11. I have included an illustration of what the coupler looks like below.
If the motor coupling is intact upon inspection, the other source of no agitation and spin would be the gearcase. The gearcase on these washers is fairly simple to replace. If you narrow it down to a failed gearcase, the next link explains the steps for replacing one:
http://www.fixya.com/support/r699497-replacing_gearcase
I could only find your model number referenced at repairclinic.com. The gearcase on their site lists for about $160 and is listed as item 423.
I could not find any exploded view diagrams of your washer, but the majority of all Kenmore and Whirlpool top loaders are designed with the same direct drive system. You can purchase a Direct-Drive Repair Manual at repairclinic.com for about $20 (Item number 1170635) if you need a guide for reference.
If you have any questions about this repair, or require additional assistance, please let me know. I hope I've given you enough to work with in trying to narrow down the cause of your problem.
Sep 29, 2009 | Washing Machines
Kenmore washer 11092597200 does not spin and has high pitch whining noise
I have attached a link to sears website and an exploded view of motor, pump and gear box. The weak link in a Kenmore washer is the coupling. Part number 13 in this view. If the machine is empty, you can check the coupling by unplugging power, disconnect water and lay machine on back. Or if strong help is available, pul machine foward, tip back and locate the coupler between motor and gear box. If it's bad it is time consuming but actually easy to change. If repairman is called, part $17.95, labor about $90.00. Inspect and let me know, I've changed many. Good luck.
Jul 01, 2009 | Kenmore Washing Machines
Kenmore 20692 top load washer won't spin. The
This is most likely a motor coupling. Pull washer towards you about two feet tilt back, look at floor for black sute. The coupling is attached to the motor to the transmission. It cost about 15.00 and takes a novice less than an hour. There are two 1/4 inch srews, one on top one on bottom , remove these use a scwrew driver to pop off the clips,pry off coupling on both side and replace.
Mar 12, 2009 | Washing Machines
Kenmore washer not spinning or agitating
hi thanks for the question don't take back off please. the problem is with the motor coupling located at the motor & transmission to repair . 2 screws at console .remove .lift console .remove 2 brass clips disconnect wiring plastic disconnect pull cabinet towards you .put a block under left front lift up remove the pump 2 spring clips .remove motor wireing . remove the motor replace the motor coupling thanks the appliance doc
Sep 06, 2008 | Kenmore 20722
Kenimore portable washer
ok" sounds like motor coupleing is broken
coupling is attached to motor
coupling can be replaced, you will see if you turn the motor
by hand that it's broken
make sure the power cord is not plugged into wall
take coupling and make and model of washer to
appliance parts store or order thru sears parts
Jan 08, 2008 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore 8series washer
pund, sounds like the motor coupler broke, It's not a hard job, I will attach a couple of pictures. You will need to remove the pump and motor to replace it. Catriver..post back
Apr 25, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
