Question about SVA-USA HD4208TIII-VR 42 in. Plasma Television
Dark box in center of screen
When i turn the tv on everything is fine for about 5 sec, then a huge dark box pops up in the center of the screen and it wont go away
  • 1 more comment
  • gerrydoot Aug 16, 2008
    When I am trying to watch a DVD using the AV1 and AV2 screens, a large black rectangle flickers in the center of the screen. It is not because of the closed captioning. I have tried turning the TV off and back on which worked once, but is not working anymore. Any ideas?
  • bosco94 Sep 03, 2008
    I have the same problem with the 20 inch SVA TV. Works for a few seconds then almost the entire screen is covered with a black box that you can hardly see through. Any solutions to this problem?
  • someboytoo Dec 28, 2009
    Hello I know this is an older post but I have the same problem now and wondered if you found out what the cause was.,. It is not the closed caption
Sounds like a version of closed captions. Go to menu section and make sure closed captions is off
Posted on Jun 12, 2008
LC-60LE600U DUNTKF908WE04
Sounds like corrupted firmware. A firmware update is necessary. Contact the authorized service center for Sharp.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 08, 2016 | Sharp AQUOS LC-60LE600U 60" LED TV...
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
How do I get picture back on TV which was working the night before, which is hooked up to HD cable box, thru HDMI?
OS info is always helpful, if say you are running some type of nix, it's likely not getting recognized by xserver or if your running some version of windows your display manager has shut it down because of a resolution mismatch.
May 26, 2014 | Amstron Fujitsu LifeBook E390 Laptop DC...
57wv600 blinks 7 times, no picture, or blue for few seconds
1. Remove the 5 screws from behind each speaker
2. Grasp bottom center of plastic panel and "pop" forward. Swing upward to remove.
3. Remove 4 screws from the wooden panel in center.
4. There is a "black box" in the very front of electronics. It will have torque paint on the 2 rows of 3 screws. top row is labeled "focus"
MY TV would go green before going black. Volume still worked.
5. I turned the center bottom screw (marked "green") appx. 1/8 to 1/4 turn COUNTER clockwise.
Plugged TV in and it works fine.
Oct 08, 2011 | Sony KP-57WV600 57" Rear Projection...
The tv made a popping noise and now my tv is dark
looks like ur screen is gone........or any other electrical problems are there.......call a service center and let it check out,,,,,,,a new screen is nearly $1000 so may a better idea to get a new tv if this is the cause
Nov 20, 2009 | Akai PDP4273M Television
Black box in center of screen
The Panasonic call center helped us with this one. Our Closed Captioning had been turned on through the TV settings. This made us have a black box with everything besides our cable. Turning off CC on our TV Main Menu solved the problem for us.
Jul 24, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Motorola v360 screen display
First thing you should try is holding a bright flashlight to the screen when it is turned on, if you do this in a dark room it might allow you to see the screen, if not follow these steps.
1. open the phone book
2. Press up once
3. press menu
4. press down twice
5. press enter
6. press up once
7. press enter, wait a sec press enter again.
hopefully that will work
Apr 24, 2008 | Motorola Mobility V360 Cellular Phone
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
Open Questions:
SVA-USA HD4208TIII-VR 42 in. Plasma Television Logo
132 people viewed this question
Top SVA-USA Televison & Video Experts
Henry  Thomas
Henry Thomas
Tony
Michael Galve
Michael Galve
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
