Question about Refrigerators
Amana Model SQD22NBW Refrigeration stopped running MFG P1162412WW
Amana Refrigeration stopped running. The only thing that appers to run is the lights. It is in the garage and I went out to get something and noticed it had stopped cooling. I emptied the freezer and refrigerator (lost a lot of food that spoiled). I left it unplugged during the night and plugged it in that morning. The fan and compressor appeared to turn on and start cooling. About 1 hour later I returned and it had turned off. I tried it again the next day and it turned off in a couple of minutes. Is this a simple fix? What parts do I need to replace.
Help,
Brent
  • 1 more comment
  • eischman Jun 12, 2008
    Please add part #'s and a quick explanation of what I need to do
    The refrig is no longer on warrentee. Only the light comes on, I hear no sound. When I let it sit for a while and replugged it in it sounded like the fan and compressor was running but then it cut off.
    You mentioned that it could be the compressor? Would the fan still run if it were the compressor? Someone told me it sounded like a defrost timer?
  • eischman Jun 13, 2008
    I am looking for th part #'s for the cold control and defrost timer that is suggested I replace.
    Does the cooling fan continue to run, if the compressor shuts off? This one is very important to know!
    When it cuts off both the fan and compressor cut off. Now it is so quickly it is hard to tell if both the compressor an fan come on.
  • 525 Answers
From your description, it sounds as if you are losing power to the running components. 1st, make sure your outlet wiring is tight and that the outlet is sound and not burned. Basically, it sounds as if your cold control is failing, but double check your outlet. If you've had any power outages or brown outs in the past few months, your cold control could have taken a hit.
Cold Control part no. 223393. Located in the freezer section, Note:
This advice is based on the information supplied by you and may not relate specifically to the model used for research. Be sure to have the model and manufacturing number handy when ordering parts. Below is a link to follow for repair assistance.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Post me back if you require any more assistance.
Thank you for contacting, Fixya.com
Dave E. (Illeagle)
Posted on Jun 12, 2008
  • 2 more comments
  • David Emmel
    David Emmel Jun 12, 2008
    If you could be a little more definitive in your observations, it may help me to assess your issue by using the process of elimination. Please make the following observations, and please be absolutely certain of what you are observing. An "I think" here will mean a non- diagnosis.
    1. Is the compressor actually running and shutting off after a few minutes of run time?
    2. Is the cooling fan by the compressor running.
    3. Does the cooling fan continue to run, if the compressor shuts off? This one is very important to know!
    1. If the compressor shuts off and the fan keeps running, then you have a compressor issue.
    2. If both the compressor and fan shut off, then you either have a cold control issue or a defrost timer issue. In this particular situation, I would recommend replacing both your cold control and your defrost timer to save you time by eliminating both components as being a suspect.
    If you determine it to be a compressor issue, then a professional service tech. is required because this part of the sealed system.
    Any more questions let me know, or if this fixes it, please let me know by rating my solution.
    Thank you contacting me at Fixya.com
    Dave E. (Illeagle)
  • David Emmel
    David Emmel Jun 13, 2008
    Hey Brent,
    Just checking back to see how you are doing. If you got it fixed, would you kindly rate the advice I provided for you, so we can get some closure. If you need further assistance, please post me back, and I will see what I can do.
    Thank you,
    Dave E. (Illeagle)
  • David Emmel
    David Emmel Jun 14, 2008
    If you go to the freezer compartment, you will see the cold control box with the adjuster knob. unplug the fridge, remove the 1/4" hex head screw, approx. 3" long. You can then remove the 2 wires attached to the terminals of the cold control, (don't touch the green wire as it serves no purpose in this test), Take the 2 wires and securely join them together and away from anything metal. Plug the unit in and if it stays running , then your cold control is faulty. That would save you from buying multiple parts.
    Post me back if you need any more assistance.
    Dave E (Illeagle)
  • David Emmel
    David Emmel Jun 15, 2008
    Checking back in to see how we are progressing.
    Have a Happy Father's Day!
    Dave E. (Illeagle)
    President:
  • 2,712 Answers
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
If it is just that the unit is not cooling properly, it could be a problem with the compressor. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
It could also be that it is simply too hot in your garage for the fridge to work properly. If that is the case, your compressor may be under strain and could have burnt out.
If your unit is under warranty, best thing to do would be to contact the manufacturer/point of purchase. (Warranty is usually 5 years).
There is no quick fix for this, and you will need to have some experience in refrigerator repairs. It seems most likely that the issue is a burnt out compressor. But whether it is the wiring or the compressor itself, will be hard to tell without testing for continuity, etc.
If you feel that you have correctly diagnosed the issue, and wish to try a DIY, I suggest you purchase a service manula first. Here is a good one:
http://www.appliancepartsworldwide.com/Store_Part.aspx?Id=501956
You can then purchase the required parts from here:
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=647313&ST=PBM
Hope that helps! If you find my solution helpful, kindly take a moment to "Accept" my solution. Thanks.
Amana refrigerator not cooling, what should be done or what should we check to determine the problem?
The purpose of a refrigeration circuit is to move heat from the inside of the cabinet to the outside.
The compressor pumps refrigerant around the circuit and if everything is ok the evaporator is cold and the condenser becomes warm. If the compressor is running but nothing inside or outside is happening either the compressor is defective or the refrigerant has leaked away.
If the condenser is warm or hot but the inside is not cold the defrosting panel might be permanently switched on.
Nov 27, 2017 | Amana Refrigerators
My Scotsman 275 is giving me a refrigeration error light after running for a couple of minutes, but the thing I'm noticing is that the water pump isn't working, yet is becoming hot. Would rather not...
If the water pump is not working, or working intermittenly, it is the first thing I would replace. Often causes for water pump failure is bearing/bushing failure and excessive limeston buildup. As for as the refrigeration error, there is a dual probe sensor that inputs temperature into the control card for the discharge temperature of the compressor and the water pump discharge temperature. You can check to see if each of these device are function with a ohmmeter and see if the resistance is 10k - 15k ohms. If either of these do not check out, it needs replaced. Next see if the condenser is dirty, excessive freeze times can cause refrigeration error due to excessively long freeze time (freeze times >60 minutes). If dirty, clean coil until you can see light through the coils. During the operation, check to see if the fan runs continously during freeze cycle. If it starts and stops or just stops, fan motor needs replaced. Any thing more will require an ice machine tech to troubleshoot with his instruments. Hope this helps a little.
Sep 28, 2013 | Scotsman Refrigerators
My amana refrigerator model # ars266zbb has stopped cooling and the compressor is running hot.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 23, 2011 | Amana Refrigerators
On the Amana comfort zone air conditioner, there is a switch that says exhaust closed. Do I want the exhaust open or closed when i have the cool on the air conditioner
Hi, when you are running it in the cooling mode, leave the exhaust open to remove the condenser hot air. If you want to run just the fan to circulate the air you can close it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 26, 2010 | Amana Comfort Zone 12M32PBEH Air...
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
Jan 11, 2010 | Maytag Refrigerators
Dryer won't run. Stops after 30secs
Sounds like the timer is going bad and it needs to be replaced. The time is located behind the knobs.
IF my answer has satisfied you please rate. Thank you
Feb 11, 2009 | Amana ALG331RAW Gas Dryer
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Jul 07, 2008 | Washing Machines
If the compressor is at room temperature and no noise coming from it your problem could be the thermostat control. If the compressor is hot and you hear a hum followed by a click the compressor may have failed. Check the condenser and make sure it is clean. In those operating temperatures the compressor is overworking in the first place and if it is not getting free air flow across the condenser it can burn out. Best condition for operating any refrigerator is to remember that if you feel hot it feels hot. They are designed to operate in an place where we live and at the temperatures we live in.
Jun 06, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
