Question about Toshiba Satellite L25-S12 Notebook
Time not correct on Laptop
Hello..
my time has not been correct lately on my laptop...about 2 hours behind all the time...even after I change it...and after re booting it is still 2 hours behind...do you think I need to change the CMOS battery? I have a Toshiba Satellite L25-S1216 and the manual does not say where it is located or how to change it...Please advice...thanks,
I think this problem is related to time zone settings. Please check the time zone of your computer by double clicking on the time in task bar. Set the time zone as per your countory.
for exp: If you are from alaska select (GMT -9:00) ALASKA
Posted on Jun 12, 2008
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
How to correct my time in my laptap
Hi! Here is the process to change the time in your laptop:
Click on the clock on the lower-left corner of your screen.
Then click "Change date and time settings"
A new window will open. Click "change date and time"
High-light the hour in the digital clock and then type the correct time. Do the same with the minute.
On AM/PM highlight it too then click the up/down arrow beside it to change it.
Thanks for using Fixya! Hope this helped you.
May 31, 2011 | IBM ThinkPad T20 2647 Notebook
I need to know how to use my new laptop battery correctly.
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
Mar 16, 2011 | Computers & Internet
My sony vaio laptop shuts down after A long period of usage
This is usually caused by 2 problems:
1 - hardware - the laptop overheats and simply shuts down; the only way to fix that is to put the laptop on a cooler like
http://www.newegg.com/Product/Product.aspx?Item=N82E16834981001&cm_re=laptop_cooler-_-34-981-001-_-Product
2 - software - Windows, during its functioning, keeps adding junk (remnants of closed programs) into its memory; when the junk start to impede corrct functionig Windows crashes; the only way to fix that is to reboot from time to time, every 4 hours in XP (or 5 hours in Vista or 7) will be enough.
Jun 15, 2010 | Computers & Internet
Is there any Homebrew firmware for the Brother Geobook Nb-80c?
you have to change the BIOS/CMOS battery. the battery is defective already. that is the one causing the behind or late time and date.
Jun 03, 2010 | Brother GeoBook NB-80C Notebook
Time is wrong after turning on the PC
Please make sure that you are in the correct Timezone. For example if you are leaving in London the Timezone should say UTC +0 London, Lisbon, etc.
To do this double click on the clock in the tray and set the timezone.
Feb 23, 2010 | ASUS A6Rp-AP067M Notebook
Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Nov 30, 2008 | Toshiba Satellite M45-S265 Notebook
Clock system getting to late
Yes, this battery maintains the laptop BIOS information including the date and time. If the time slows down it indicates the battery is nearly flat and needs replacing.
Nov 11, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite L25-S12 Notebook Logo
130 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
