Question about Seagate Barracuda 7200.9 300 GB SATA Hard Drive
Wiring too hot and burnt through IC unit
Problem .....looking at the back of the hard drive the medium sized black
square appears to have had the wiring from underneath burn through
as you can see the black material has melted.
I think this is called an IC unit. How can we retrieve our files if we cannot
get power to the hard drive because of this maybe burn out situation?
Would appreciate a very quick reply.
Many thanks
Caroline
  • Seagate Master
  • 4,397 Answers
There are specialist companies that make good profits by retrieving files from damaged hard drives for people who haven't had the foresight to back them up. If the files are important or essential you should consider using such a company and your insurance might pay part of the cost.
If the files aren't very important a local computer boffin could dismantle your hard drive and fit the hard discs into a healthy drive of the same type and it might work...
Posted on Jun 18, 2017
3 Suggested Answers
  • 39 Answers
SOURCE: Harddrive has no Total size and Free space on my windows explorer
yes, probably this can be solved.
does the harddrive still have a letter assigned?
if so. go into command prompt (start->run->type"cmd")
when the black window pops up write:
chkdsk x: /r (where x is the letter assigned to your 120gb disk)
please reply if your harddrive doesnt have a letter assigned.
Posted on May 29, 2009
  • 341 Answers
SOURCE: i connect my hard drive with another computer when
if you plugged or unplugged a HD to a computer when the computer is running, you have quite probably fried the HD *unless it's an EXTERNAL HD with a USB connection, which could be more resistant to this type of abuse).
I suggest you download SeaTools from Seagate and check the HD, but I think it;s pretty sure to say that it's gone
Posted on Mar 28, 2010
Fahrenheat ffh1614 wall heater gets bright orange and way too hot
You need to check the breakers or the actual power because I see the 1614 model as being 240 Volts. Unless you can change that rating inside the unit itself and it has been set to 120 Volts. IT appears from the wiring code you listed that the building wires are 120 volts. However a meter would be the definitive answer. When you are running 240 or higher (double phase) Black and Red are hot and white is neutral If it is 110 then black is hot and white is neutral. Since I cannot tell from the description posted whether the red is source or inside the heater, you really need a volt meter.
Dec 15, 2017 | Fahrenheat (FFH1614) Wall Mounted Panel...
Blower motor only works on low and medium on 2007 dodge nitro
You replaced the resistor and WHAT relay? The blower motor circuit on a 2007 Dodge Nitro does not use a relay.
The blower resistor gets it's power from the A/C - heater control unit.
If you check for voltage at the blower motor resistor connector (Key on, relay disconnected), the DARK BLUE/GREY wire should be hot when the control switch is on HIGH. The DARK BLUE/VIOLET wire should be hot with the switch in the MEDIUM 2 position.The DARK BLUE/ORANGE wire should be hot with the switch in the MEDIUM 1 position. The DARK BLUE/BROWN wire should be hot with the switch on LOW.
If any of these are not as stated above, then you either have a bad A/C - heater control unit, or faulty wiring between the control unit and the resistor.
Jun 02, 2012 | 2007 Dodge Nitro R/T New Cars
How do you remove a hard drive on a Sony Vaio VGC-V617G? Thank you
The hard drive is located in the rear of the base. Remove the black plastic cover. Just look for the black screws holding it in then pull it back and up. The hard drive is held in place by four screws on the back side. Some components in this PC are for laptops however the hard drive is a standard PC size and connections.
May 25, 2011 | Sony VAIO VGC-V617G PC Desktop
Transmission shifts into reverse nice and smooth...shift into drive and there is no noise nor does it engage at all into drive??? This happened after car was stuck in snow...after shifting from drive and...
u should check ur transmission fluid to see if it is dark (burnt) if so ur gonna b outa luck u most likely burnt it up. fluid will also have a strong burnt smell if it is black. trannys build up alot of heat wen trying to get unstuck in snow an ice. diminished air flow through radiator or trans cooler wen stuck also adds more heat to the unit,especially wen running it hard on ice. they get hot really fast
Apr 09, 2011 | 2003 Ford Mustang
One channel ceased to work. Found transformer to be bad and replaced it. Turned unit on and the top circuit board at front off unit was getting hot and a burnt odor appeared immediately. Found a...
The part is a 4560 (generic opamp IC. The damaged IC is more likely to be the symptom not the cause Remove the IC and the cap. Replace the cap, but not the IC and measure pins 4 and 8 to ground. These should be the power inputs and measure +/- 5 thru 12 volts. They should be equal but opposite. Should htey be different, check the power supplies or any filter caps.
Update this with the results.
Thanks,
Dan
Mar 22, 2011 | DBX 2231 Home Equalizer
Double pole 30 amp square d breaker is getting very hot when i run my forced air heat - why?
Not enough amps. Check your wire size and see if it's safe to up the size of your breaker without having to run new wires
Dec 30, 2010 | Square D Trilliant 100 Amp Circuit Breaker...
A strong odor emanates from the back side of the refrigerator..spreading through out the kitchen and surrounding area..for almost a month now. The wires/tubings were brushed and cleaned, as the flooring...
Hi,follow the stepwise solution provided below to help you get rid of the odor emanating from your refrigerator;
STEP 1 You have to get charcoal,For the charcoal you can buy regular charcoal briquettes and use a hammer to crush them into small chunks
STEP 2 Combine the charcoal, baking soda, citrus peel, cloves, and vanilla extract in a medium-size glass or enamel bowl. Stir mixture and let it sit for at least 1 hour.
STEP 3 Create a sache with the mixture by putting 2 tbsp of the mixture in the center of a nylon stocking square and then placing this packet in the center of a square of the porous fabric. Tie the corners together with the string or ribbon.
STEP 4 To use, tie a packet in an inconspicuous spot in the refrigerator or freezer. Or tie onto a shelf inside the door.
Thanks and take care
May 02, 2010 | Frigidaire FRT17G4B Top Freezer...
Seagate Barracuda 7200.9 300 GB SATA Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
