Question about Canon ZR60 Mini DV Digital Camcorder
Streaks in playback
Lately, my camcorder will show horizontal pixel streaks while playing back. I'll see the actual image on every other line and it's moving along in actual time while the other lines remain frozen of another image altogether. Then, it "catches up" and runs fine. However, I need to play something for a crowd and I need to have the actual image I've taken. Are you familiar with this?
    Champion:
  • 203 Answers
The first thing i would do would be to try a head cleaning tape-if that doesn't help see in your book or menus if you can adjust the tracking on the camcorder-when the tape heads get worn over time they need to be aligned and that is what tracking does-some older models allow you to manually adjust-good luck!
Posted on Jun 12, 2008
Gray horizontal lines in video playback
dear ,
i Jasdeep working in superb broadcast as an lengineer .and for this problem i can suggest u the following things :
1. Play back the cleaning tape for 10 sec. only then use it.
actually this problem occurs when the head get clogged (i.e, dirty ) it REC. only single band and shows the same in play back too.
Jun 27, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
Jun 25, 2009 | Canon MV750i Mini DV Digital Camcorder
Grey lines across video display
pls rate me WELL if i have helped u !
Regards
Zohail
May 20, 2009 | Canon ZR200 Mini DV Digital Camcorder
Horizontal Streaks accross my lcd during record and playback
Are you trying to shoot from a TV or computer monitor? If so, check the frame rate--30frames per sec (fps) or 15fps. If it is on 30fps, changing to 15fps should solve the problem.
Feb 06, 2009 | Canon ZR60 Mini DV Digital Camcorder
Canon XL2 wont record or playback tapes - grey
Sorry to hear your situation, usually when serviced by a technician, head and tape path is cleaned and adjusted. During use you will encounter pixelation problems occur and most case tape cleaner should resolve the problem. Your condition is where if all the system is ok and have a heavy clogging on the heads, requires technician to clean each head manually to bring it back. so look for a camcorder repair facility locally and get cleaned. If you cannot find one, the service is provided for around $100 at www.camerarepairjapan. Good Luck
Feb 03, 2009 | Canon XL2 Mini DV Digital Camcorder
Panasonic PV-GS39---playback problems
You better take in to get it serviced. It could be the take motor or a head adjustment needed.
Jun 13, 2008 | Panasonic PV-GS39 Mini DV Digital...
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Horizontal snow lines on record and playback
the symptom is caused by a dirty video head. sometimes cleaning tape cannot do all the jobs, especially when the dirt is so much that any cleaning tape cannot remove it. open the cover, use a clean white paper dampened with a little alcohol. use your finger on the paper and gradually move the head drum back and forth. donot move the paper up or down. just move the drum slowly. good luck!
Jan 31, 2007 | JVC GR-FXM38 VHS-C Analog Camcorder
Canon ZR60 Mini DV Digital Camcorder Logo
174 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
