Its a problem with the printer and not the s\w.....
u can..
check if any particles have fallen inside the printer...
Try to move the cartridge carries manuelly....move the roller...
Turn the printer up side down and shake it well but be carefull cos it has a scanner glass....
And also try...
U wud find a small transperent strip of width 1\4 inch...which runs all the way across behind the cartridge carrier....
Gently whip the strip with a cloth....(BE CARE FULL ...IF THE STRIP BREAKS OR GETS OOUT OF PLACE THEN UR PRINTER HAS TO BE REPLACED)
If still same problem then ....ur printer has to be replaced and if it is under warranty the lexmark might replace it for u
1.
Remove the sheets of paper from the feeder. 2.
Grab a flashlight and look inside for any debris. 3.
If you're willing and physically able, you may also turn the printer over. Any
debris should just freely roll out from the feeder. 4.
If feeder is clear, place the printer back on the table, open the printer cover
and remove the cartridges. 5.
Check the cartridge area for any obstructions/debris that could cause this
error or problem. 6.
If cartridge area is clear, close the cover. 7.
Unplug and re-plug the printer into the power outlet to reset it. 8.
When the printer turns on, reinsert the cartridges and load some paper. Try to
print again. You may also refer to this article in the Lexmark website: How to Remove and/or Avoid a Paper Jam in your Lexmark X5300 & X5400 & X5600 Series All-In-One
