Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer MD6
Purchased second hand 5 or 6 year old maytag dryer everything seems to work but have no heat..... how do we check the heating coil ??
  • lelala Nov 12, 2008
    No heat. Bought Neptune MD-6 secondhand. Owner used it that day to dry clothes before new set arrived. Had to lay on back to transport. Hooked up exhaust and power cord. Runs but no heat. Checker our ciruit breaker. Read in one article that have to use 220 to work? Is that correct or should 110 be fine. What should I do to attack this problem?
  • 254 Answers
All you need to do is check the element for continuity with an ohm meter, if it has continuity the element is good. The dryer also will run on 110 volts of power but it needs 220 volts too run the element, so check and make sure all the conections on your cord are secure and that you have 220 at your wall outlet.
Posted on Jun 12, 2008
I have a maytag neptune which is about five years old. It runs fine, but the dryer does not heat up. What should I do orcheck to diagnose problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The dryer is 5 years old and does not seem "heat"
werrw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. If the problem does not inprove, you may have a defective heat coils
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Dryer says 8.8. on display
Put a heating pad over the display panel. After 5 - 10 minutes, the display panel will return to normal and the dryer will work,
Jan 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune - everything works, not getting hot
check to see if it has an igniter if so that could be your problem.
Nov 22, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer purchased 5 years ago - panel completely lit up
you may have it in advertising mode
Try Pressing the damp dry and sensor dry keys
for 5 seconds will take it out of the
Advertising mode.In Advertising mode No functions will be run
except illuminating the LEDs
Let me know if it works
Oct 08, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Neptune Drying Center MCGAWW (No Heat)
Sorry no pilot light but you have ignite, flame sensor and a gas valve...all control heat...
let me know if I can help
krazytech
Mar 30, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer
you are correct. have an electrician inspect the house wiring, especially for HIPOT test for insulation and shorting test.
Sep 16, 2007 | Maytag Neptune MDE6700A Electric Dryer
Maytag neptune dryer won't start
Just a quick question before I look at the control board myself. What are the values/ratings for the capacitor and resistor (ex. farads for cap, ohms for resistor, and volts/amps for both)? Or give me the Vender Part Number so I can look this information up. Thanks!
Jan 27, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
675 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
