Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Keys and keypad locked
Hi
oneday i was using my laptop and the nxt thing i notice the keyboard and keypad were both locked! my husband and i are not used to using windows vista and we dont knw what is wrong or how it happened.
but we can use a keyboard and mouse if we plug in one. Can you help us please.
  • Anonymous Aug 12, 2008
    MY KEYBOARD IS LOCKED
    Scholar:
  • 164 Answers
Hi1
There may be a real simple fix for this.
Go to your "System Restore" in system tools.
Restore your computer to any date prior to this issue that everything worked.
Vista is a mess!
P.s.
Since I have no idea on what all you have done, I have some questions / suggestions.
1st: Have you Defragmented your computer? If not this month, please do so ASAP.
2nd: How much free space is left on your hard drive? You need over 15% free space.
3rd: Have you cleaned out you cookies, temp Files & Temp. Internet Files?
Mastersage....................................................
Posted on Feb 20, 2009
Turn off num lock laptop
Hi aidatul, please try these steps
1. Choose Start---Control Panel---Ease of Access---Ease of Access Center.
2.Click the Start On-Screen Keyboard button.
3. Click on the 'num lock' key once to turn it off
Close the keyboard and try to type.
Jun 19, 2013 | MSI Computers & Internet
Numerical keypad offset numlock on keyboard
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Nov 18, 2012 | Genius KB9229047 Keyboard
My numeric keyboard is not working, the num lock is on.
Have you tried booting up in safe mode to see if it does the same thing? Also check your keyboard to see if there is some type of key combination that locks or unlocks the numeric keypad. If so, usually you will have to hit the FN key or the ALT key or the CTRL key plus some other key to get it to toggle.
Mar 31, 2012 | Toshiba Computers & Internet
When i press a character key from kayboard it displays digits
The RIGHT side of the keyboard has multiple labels on each key -- alphabetic and numeric.
Press the KEYPAD LOCK key to use the "keypad" layout.
Press the KEYPAD LOCK key again to use the "alphabetic" layout.
Nov 12, 2010 | Sony Computers & Internet
Why do I get a 1 when I type a j?
Hi, this is becasue your "num lock" key is truned on. on laptops there is no numer keypad so when you press the num lock key some of the letters do double duty as numbers. Just press the num lock key again and it will turn your keyboard back to normal.
Sep 03, 2010 | Gateway Solo 9100/9150 Series Laptop...
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
Feb 04, 2010 | Microsoft Windows XP Professional
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
ACER 5620 Extensa keyboard problem.
Hi, your Laptop has a integrated keypad. You or someone else might of turned this on, thankfully it is easily fixed. Just follow these steps,
1. Find and press the "Fn" key.
2. Find the F11 key there should be in blue letters "NumLk"
3. Press F11 while holding down the Fn key.
This should turn off the integrated keypad
Hope this works ~Kaleb~
Nov 12, 2008 | Computers & Internet
Function Keys
hi there
you have lock the the number on the keypad to remove this function as caps on caps off simply press fn and key F11/numLK same time and it will return to normal letter function on your keypad
May 19, 2008 | Acer NSK8458AN Keyboard
Keyboard
The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
Feb 10, 2008 | Compaq Presario 1275 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
1,060 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
