Question about HP LaserJet 1200 Printer
All lights are on (Laserjet 1200)
All are on and I do not know what to do next. I have push and held in the big light button but nothing happened. What do I do?
  • ithankyou Jun 12, 2008
    All lights are on. I have pushed and held in the big light but nothing happens. I have unplugged the printer and still does not working. What do I do next. I need help and hopefully not a new printer.
  • tonykhabo Aug 21, 2008
    all printer lights on ( started after power cut)
    : tried to switch of printer to clear memory
    :changed printer cable
    all of these did not work
You should check your fusing assambly and scaning unit
Posted on Jul 19, 2008
Model mgh-055 furnace. Why won't it light?
Pushing down the button causes enough gas to be fed to the pilot to allow it to be lit and remain burning. If nothing happened, the gas valve could be at fault.
Sep 20, 2015 | Heating & Cooling
How can I get the player remotes to connect to the xbox360?
First you hold the big X button in the middle to turn the controller on. Next, after making sure your 360 is turned on, push the connect button on the 360 controller so the lights around the big X are spinning around. Finally, push the connect button on the 360( which is located directly to the right of memory unit B) and the lights around the on/off button of the console should spin. Eventually, your console will find the controller, and you will know its connected because one single light on the controller will remain lit while the others wont.
Sep 10, 2012 | Microsoft Video Game Consoles & Games
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
When i push the start button nothing happens ,there is lights but no signal lights. the key icon turns on and the engine icon also turns on.
Have you tried checking the kill switch on the right handlebar controls and make sure it is in the "run" position.
May 16, 2011 | 2004 Harley Davidson XL 1200 C Sportster...
Hp 2200d laserjet
possiably bad gear assembly.
Sep 21, 2008 | HP LaserJet 2200D Printer
HP Laserjet 1200 - continuous blinking yellow light
A flag is a little plastic piece that is hinged and goes in between a sensor and a light source. They use a ton of them in printers. It actually looks like a flag, about 1/8th inch square that can move in between the sensor parts. It's possible that it broke when you took the envelope out. Most likely it's the paper exit sensor in the fuser. They can break easily. If so, then you'll have to get the sensor flag or a whole new sensor. Check with a local repair shop. They should have the sensor and can install it in a jiffy.
Aug 08, 2008 | HP LaserJet 1200 Printer
Hp laserjet 1200 printer problem
press the big button for secondary light pattern error code
most likely you have a bad fuser
thanks for rating
Jan 14, 2008 | HP LaserJet 1200 Printer
HP LaserJet 1200 Printer Logo
179 people viewed this question
Ben Johnson
