Question about BenQ FP767 17" LCD Monitor
Monitor on but no/very feint display
Second & third faults are the inverters. (power but no image visible, but feint if you shine a light into the screen)
Check the 4 transistors on the main power board for shorts.
Found the above solution - sounds like my problem.
However, I am not sure how to check the transistors. Can you provide a little more detail???
  • 472 Answers
Sorry for the late reply, I was sent away for 2 weeks in the middle of nowhere.
Anyway to the problem at hand..
The transistors are easy to check. They have 3 legs so think of them as 1, 2 (middle) and 3
Using a multimeter on continuity mode (should give a tone when the probes are touched together) put one lead onto pin 1, and the other onto pin 2. You should get a tone for no more then a half a second at most. If you get a solid tone, it has shorted out.
Move the leads to the pins in various combinations to cover all possible connections if you get no tone from the first test. One short and it needs to be replaced.
When you replace the transistors in these, replace them as a pair. There are 2 transistors that work together at each end of the board. (4 all up)
I have done up a very long conversation with another on here, so just look through my posts and you will see it.
Posted on Jun 16, 2008
My monitor goes blank after a certain period of time. When I try to wake it, it doesn't come back up. If I shine a light directly down on it, I can see the icons, I can barely see everything get to the...
Hi kellbro1,
You're problem is not in the settings but in fact there's a three major parts involved for fault. First is your back light, second is your inverter board, third is your power supply. I've suspect that you're inverter board or its power supply caused this problem. If you have necessary tools and test instrument, know safety precaution in basic troubleshooting you may isolate the trouble. You have to test the inverter board by loading a two car bulb in series with it. Constant glow of light means you have a good inverter board and the backlight(lamp) need to be replaced, irregular glow of light means that you have a faulty inverter board.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 23, 2011 | HP f1905 19" Flat Panel LCD Monitor
Acer AL1715 power issues
I have an ACER AL 1706 monitor that would not power up completely. After pushing the power button, only the yellow light would stay on indication a power up fault. After careful inspection of the power boards caps, there was visible swelling of the 47mF and 22mF radial caps on the top part of the caps where the tiny cannisters 4 edges are folded down flat. I replaced these caps( 6 on my board) because there is reaaly no way to actually test them and bought new ones from Radio Shack. Now my Acer monitor came back to life with no other problems. I recommened using replacement caps with same microfarad values, but if the voltage rating is not exact, it is o.k. to get the next higher voltage rated caps available and should work fine.
May 01, 2009 | Acer AL1715 17" LCD Monitor
Monitor displays breifly then goes to blank screen
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
Black screen no picture
Your inverter has died and is a very common fault with all LCD monitors. The inverter powers the lights that sit behind the screen so you can see what is happening. So no lights, no picture.
Shining a bright torch at an angle from the top you will be able to see the image on screen, but very feintly.
This is something your local TV repair shop will be able to take care of fairly cheaply. It's not a good idea to play around in these types of monitors unless you have some understanding of what lay ahead.
Let me know if I can help further.
Apr 08, 2008 | BenQ FP91G+ 19" LCD Monitor
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor will not power up
Hi tafkab, Sounds like it's probably the backlight inverter board. Try the test I have at the bottom to see. It's a very common problem. LCD's use four small Cold Compact Fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, Dude
Nov 25, 2006 | Acer AL712 17" LCD Monitor
Monitor goes blank
Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 16, 2006 | Dell E153FPc 15" TFT LCD Flat Panel...
My monitor just flickers off, glitches on for a split second, then glitches off. I know its not the settings on the computer because I have another computer that works fine, but when I plug this monitor to...
Hi imkindacool, Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 06, 2006 | Liquid Video L17LCD2 17" Flat Panel LCD...
BenQ FP767 17" Power but no display?
Different faults here.
First fault is no power, it is bad capacitors on the power board.
If you are unsure what that means, then take it to your local TV technician, he should be able to solve it fairly cheaply.
Hope that helps.
Oct 11, 2006 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Logo
141 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
