Question about True TDD-4S Beverage Cooler
True refridgerator I have a 10 cubic foot fridge. It would not cool at all, but the fan in the top was on but the one on the condensor was not. So I unplugged from the lower box and pluged it into wall and it worked. What is broke? thermostat?Please email me at russleecarr@yahoo.com
  • 122 Answers
Sounds like the thermostat is bad. Try plugging that bottom unit cord for compressor into an extension cord, and plug the main power cord fronm unit in to a recepticle, if it starts cooling you need a thermostat. I can hook you up with one. ;) www.northeastcooling.com
Posted on Sep 23, 2009
GE fridge not cooling. freezer working ok. compressor fan not working
This is an odd thing to hear. Normally when the condensor fan (}compressor fan) Isn't running the freezer is the one who's temperature rises and the fridge stays about the same. I would strongly suggest looking at the main control board, just for the simple fact that 9 out of 10 times thats the root of the problem
Jun 06, 2012 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
True gdm 26 no longer cooling. Internal tem 80 degrees, Condensor fans running, Coil is not showing any frost or icing. Removed cover and cleaned coil and removed dust and dirt. Went out "all of a...
sounds like the compressor is not running. The condenser fans are located at the compressor. The fans in the conditioned space are the evap fans. A refrig usually does not have any device controlling the evap fans, they are to run 24/7. Freezers have other controls. Start there and let me know if I can help further.
Nov 20, 2010 | True GDM-26 Refrigerator
My GE Side by Side is not working wierdly. the top few shelves on both the freezer and refridgerator are not cooling but the bottom shelves are cold.
Check to see if your evaporator fan is blowing in the freezer, then check your condensor fan behind the back panel. If those are both running make sure your coils are clean underneath your fridge. Cold goes down heat goes up, that's why it is warm up top and cold down. Start there. Good luck!
Aug 21, 2010 | GE Refrigerators
I am looking for the dimension and capacity of fridge 69852990
Measure Exterior Height & Width and Depth for Dimension.
Interior Space = Then, Measure all open accessible area inside the fridge and add the two together, following the formula of H+W+L Freezer and H+W+L Refrigerator,add together and BAM ya got cubic inches.= Square inches, then divide by 1,728 (the number of cubic inches in a foot (3) Cubed.
Example 1: 60 inches tall, 42 inches wide, 30 inches deep = 75600/1728 = 43.75 Cubic Foot AREA
Example 2: fREEZER dIMS = 24 DEEP x 18 HIGH x 36 WIDE =15552/1728 is 9 CuFt. Refridgerator 36 wide, 36 high 28 deep = 36,288/1728 = 21 CuFt. + 9 CuFt. = 30 Cubic Foot Capacity.
By the Math Wiz RUDY :)
Apr 18, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge not cooling freezer iceing up???
check the fan in back of freezer check or proper running condition not stuck or frozen also make sure not blocked by food the fan takes the air from freezer and blows it down into fridge area to cool it also check for ice build up in the fan housing and thaw as necessary
Nov 15, 2009 | Avanti Top Freezer 9.9 Cubic Foot Total...
Our 10 year fridg seems to get very hot on the side...wondering what would cause this Model et18pkxaw00
The condensor coils run along the inner sides of the fridge . The heat you feel , is the heat being pulled out of the freezer which is the purpose of "freon" (to attract heat) . A freezer doesn't get cold , "freon" pulls the heat out , which is then cooled by the condensor fan ( fan which cools the compressor and coils ) . The more heat you feel , the colder the fridge should get ( to an extent ) . Also make sure the compressor fan is working .
Aug 19, 2009 | Whirlpool Refrigerators
True gdm-12, condenser fan
should not be on all the time only when it is cooling.. make sure your fan and blades and condensor are clean this will make your fridg cool better and run less should be cleaned at leaste once a year.....
Aug 12, 2009 | True GDM-12 Refrigerator Commercial
For the second time this year my fridg is quit working. I is only about 7 years old. It is not cooling on either side. The ice maker is not freezing the ice very well it ends up freezing in lumps that we...
Check behind the fridge where the compressor is and see if the condensor fan is working,also clean all the dust out of the fan area eg condensor. Hope this helps Kind Regards.
Jul 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Refridgerator not cooling
Hi, Try these settings..
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the refrigerator or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak                                      Pls rate my suggestion..thank you
Apr 11, 2009 | GE Refrigerators
True TDD-4S Beverage Cooler Logo
106 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
