Question about Toshiba Satellite A15-S127 Notebook
Cooling Warning Setting pop-up
Fans are working , not overheating. How do I turn off the pop-up warning that keeps coming on?
Open up the fan cover and dust everything with compressed air!
Posted on Sep 07, 2008
  • Toshiba Master
  • 2,794 Answers
Check Toshiba.com for an upgrade on the thermostat.
Does it feel too hot to you yet?
Posted on Jun 12, 2008
I have a 2008 Chevrolet Silverado and the warning lights keep coming on telling me AC not working/engine hot ,, ??
ENGINE HOT TURN A/C OFF
Cooling System Description and Operation
ENGINE COOLANT HOT
The instrument panel cluster (IPC) displays ENGINE COOLANT HOT message when the IPC receives a class 2 message from the powertrain control module (PCM) requesting illumination of this driver warning.
ENGINE OVERHEATED
The IPC displays ENGINE OVERHEATED message when the IPC receives a class 2 message from the PCM requesting illumination of this driver warning.
DTC P1258: Engine Coolant Over temperature - Protection Mode Active
Have it check
Mar 03, 2017 | Chevrolet Cars & Trucks
My car said "engine hot
Full coolant level does not mean your engine cannot overheat. You need to fix the problem as overheating will destroy the engine if not addressed.
The radiator cooling fans must be working, as must the water pump. The thermostat must also be working properly.
There must also be no air in the cooling system as air locks will impair water flow. When cooling systems are drained fully or partially and re-filled air in the system must be bled out using the correct bleeding procedure for the particular engine/cooling system. Failure to do this properly will lead to overheating.
If you ONLY see the overheating warning when running your aircon you need to check that the electric radaitor fans are kicking in at idle when you switch on and run the aircon and the engine has been warmed up some. If they do not start operating when the a/c is running you will get an overheating condition in normal driving conditions.
If the radiator fans are operating normally and you still get an overheating warning when the aircon is on or off the most likely culprit is a faulty thermostat in the engine's cooling system which will need to be replaced.
If you have either a faulty thermostat or if the water pump in the cooling system fails you will get continuous overheating whether the aircon is on or off.
Sep 05, 2011 | 2006 Chevrolet Impala
Warning: fan locked contact service center for
di pasang kipas baru tapi masih bertuliskan warning fan locked terus mati..projektornya
Jun 23, 2011 | Optoma HD65 DLP Projector
2003 Jeep Grand Cherokee... Overheated and the 'trans overheat' light came on. When I popped the hood the coolant res was bubbling. I let it cool down and parked it overnight, when I started it, it was...
You can no longer use the vehicle,common sense
Sounds like either the thermostat stuck closed,the cooling
fans failed to come on, or you have a bad head gasket.
You do know that the engine is overheading and has to
be diagnosed and that issue repaired
That Trans Issues, you work on after the engine overheating.
Even if the trans is okey,you will need to change the
fluid,not flush it.
Apr 25, 2011 | 2003 Jeep Grand Cherokee
I have bought a new toshiba A665 a week ago. I have a problem saying. ' A problem in the cooling system has been identified. Switch off ur computer and return it for service.' Cooling fan is working but...
At a week old, get a replacement or fix it right away. Fix should be free, but no computer during service.....
Toshibas run too hot, in my opinion.... so you have to keep after the fans and keep lint cleaned out of it....
Overheating will yield un stable system,
Feb 26, 2011 | Toshiba (K000831860) Cooling Fan
My car keeps overhating because my fans wont come on. i changed the radiator temp control switch and the thermostat
Warning! I don't know how to fix this problem but I do know it's very dangerous to work on these fans. THEY CAN COME ON UNEXPECTEDLY WHILE WORKING ON THEM AND INJURE YOU. These fans can run even when the key is off. Take it to a shop that knows how to work on them.
Nov 10, 2009 | 1995 Buick Roadmaster
Overheating again
The heater stopped working because there was no coolant in it. Your real question is where is the water going.
Have the cooling system pressure tested to be sure you have no leaks. You said you had the radiator flushed, I suspect some of the tubes are blocked, it should be dissassembled and rodded then cooked out. Not just flushed. You problem is in traffic, low speed. The car starts to over heat, it blows the water out of the overflow, the level is down, the heater stops working, then you are out of water in the engine and overheating.
BTW ground the wire that goes to the warning light sensor and be sure it lights the warning light. If htis is the case the sensor is bad. I assume when you turn the key on but before starting the light does work then, correct? That means the bulb is ok, that does not check the sensor.
Good Luck!
Feb 09, 2009 | 2001 Ford F150 Styleside SuperCrew
System warning pop-up
Are you sure that nothing is overheating? If your cpu fan is turning too slow it won't disipate the heat. Do you have a program showing cpu temp:? I would take the access off the bottom and make sure the cpu fan is clean. If that is not the problem I believe you can turn the warnings off in the bios settings
Jun 08, 2008 | Toshiba (K000016310) Cooling Fan
Toshiba Satellite A15-S127 Notebook Logo
78 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
