Question about Hitachi 51F59 51" HDTV Projection Television
Hitachi 51F59 51 in Projector no picture or sound
The tv is definitely turning on but has no picture or sound. We can even pull up menu options. At first we thought maybe the cable went out, but all other tvs in the house are working.
  • hollyhun Jun 12, 2008
    Well I did something magical and fixed it myself. I disconnected the power and carefully removed the back panel. Then I gently blew some of the dust off the circuit borads. When my husband came home I told him I took the back off and was looking on line for some help. He tried turning it on just to see what would happen and wa-la it worked. Sometimes I guess it just takes a little magic blowing and positive thought!
  • dj_bearnekki Nov 27, 2008
    tried dusting it out and powering down and still nothing any ideas and where can i get parts btw how do i do an upgade to it when i do get it working again?
  • 8,596 Answers
Resetting the tv by unplugging is definitely a good idea. dusting doesn't hurt either, because the dust can sit on the circuit board. when the dust heats up through use, it can cause damage to the circuits that unplugging and replugging won't fix :-)
Posted on Jun 12, 2008
I have a Hitachi CPX3021WN projector I rarely use and a few days back when I put it on there was a large pinkish purple blob on the screen. This blob starts from somewhere in the mid lower area and th
It sounds like there are some magnetic fields around your projector. Similar to what used to be degaussing in an older tube TV. Sometimes it may be that the speakers are to close to the projector or even the earths magnetic field that may be effecting it. Try turning the projector in a different direction and see if that helps your problem.
Nov 20, 2014 | Hitachi Gst Hitachi Cpx3021wn Hitachi...
I can't get any sound from my Hitachi 42PD5000
Make sure the speakers have not been turned off in the menu.
Apr 30, 2014 | Hitachi Televison & Video
Hitachi 51f510 sound no picture
select hdmi on menu or dvi/component on tv
Jul 05, 2013 | Hitachi 51F510 51" Rear Projection...
Samsung hitachi sync out of range
take the blue ray disk out, turn your blue ray on and connect to a tv monitor, go to menu, and for hdmi option select 720p then reconnect your hdmi cable to the projector, it should come on, go back to menu, and match the input of the projector to the right type hdmi output from your blu-ray.
there is nothing wrong with your projector.
tony
Feb 20, 2013 | Hitachi Office Equipment & Supplies
How to reset the lamp operation time on a hitachi lp700?
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jul 31, 2012 | Hitachi LP700 Replacement Lamp
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
I am trying to project a presentation from my toshiba laptop to a Hitachi data projector (new). The desktop and all have a red/pink tinge. i even tried just going into my pictures and doing a slide show -...
This sounds like a bad cable... do you tight the scew? inspect the cable connector at each ends to dbl check that there is no damaged pin, and also on the projector side...
Oct 15, 2009 | Computers & Internet
Hitachi model 43uwx10b comes but no sound or
sounds like one of the transistors attached to a heat sink shorted out.
you will need to test each one with the tv unplugged.
set the digital meter on diode.
it`s not easy to explain the rest, sorry.
Sep 08, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi projector cp - s210
hi there,
I have just done the exact same thing today. Press menu button on projector. Scroll (navigate) to the mirror option. This give you the options to mirror image left to right or up and down.
This should fix any of your problems.
Cheers
Luke
Feb 03, 2008 | Hitachi CP-S210 Multimedia Projector
Upside down picture
Use the mirror function from the menu as per the picture below choose V:INVERT. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 25, 2007 | Hitachi EDPJ32 480p Enhanced Definition...
Hitachi 51F59 51" HDTV Projection Television Logo
274 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
