Xerox Workcentre Pro 416DC
When we turn on the copier, and it begins to warm up, we get a message saying "Call For Service". We have tried different things, like holding down the 0 and 8, and then typing in 400. Or holding down the 0 while it is starting up. We opened one of the side doors before we turned it on. the machine started up, and showed a message telling us to close the door. When we did, the message read; "Wait: Warming Up", and then it said "Call For Service".
It appears that the problem is with the warming up process, and we are assuming that we may need a heater lamp, or possibly a thermal control device.
Do you have any advice on what the problem may be, what part we need, and where would be a good place to purchase it?
Thank you very much
  • 42 Answers
Try holding down the "8" and "clear/stop" simultaneously to get the malfun. code
Posted on Jun 20, 2008
How i do fix error e161-403e
Try holding the Navigate + Load buttons down while turning it on... keep holding them down, as it could take quite a few seconds before the LCD says Initializing
S should appear at the top right of the display.
Press the < or > keys to choose the Set./Adj. Menu and press the OK key.
SERVICE MODE should appear in the menu list and the MESSAGE LED should flash.
Press the ^ or V key to choose SERVICE MODE and press OK
Apr 29, 2015 | Canon imagePROGRAF IPF710 Printer
HP Officejet 4500 three in one has error 346 and cant fax out. It dials the number correctly but as the fax begins to connect, the number changes to a plus sigh in front of it and puts a dot in between...
Error 346 means the connection was interrupted. Try a different phone cord or jack. If you have a voicemail service that 'pulses' the dial tone when you pick up (to let you know you have messages), it can cause that error too; try clearing the messages.
Adding the +1 is normal when dialing with the area code (using a 10-digit number). If you weren't using the area code, try it.
Otherwise, as a last resort, you can try resetting the fax back to factory default:
-turn off and unplug.
-Hold the # and 3 keys down while plugging in the power cord. If that doesn't work, try # and 4.
Mar 24, 2011 | HP Office Equipment & Supplies
Konica minolta bizhub c350 c-0500 display
Fuser warm up failure. Most likely this will require a service person to repair but here is the reset procedure you can try yourself. If it does not reset then you will need a service technician.
Turn off the main power switch located on the right side of the copier, NOT the one on the edge of the operation panel. Press and HOLD the utility/counter button on the control panel. While holding this button down continuosly turn on the main power switch. Continue holding the utility counter button until the screen changes to a blank screen with just a box that says "trouble reset". Now release the utility/counter button and touch the trouble reset box. Now turn off the main power switch for a few seconds then turn the machine back on. The code should be gone but if a problem remians then the code will come back within 30 seconds.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Konica Minolta DiALTA Di200 Copier
Ink Low message after installing new cartridge
There is no way to actually "reset" the counter. IF your MP170 has a RESUME/CANCEL button, Press and hold this button for about 7 seconds to bypass the counter (The PAGE FEED button will work for some other models). If your printer doesn’t have this button, you may bypass the counter by turning the printer OFF. Now hold down the RESET and turn the printer ON. Keep holding the RESET until the printer boots and initializes. When the display says, "INK VOL UNKNOWN" you may release the RESET and begin printing in the usual manner. You may need to start the printer in this manner each time, or the printer may remember this setting. Canon was experimenting during this time so some of the same models have different buttons and bypass tricks. Hope this helps.
I hope this helps you.
Sep 13, 2009 | Canon PIXMA MP170 All-In-One InkJet...
I am getting an error message "S545"
Fuser unit malfunction code.Check the connectors,thermistors and thermofuses.Reset the code :enter in the service mode (press total clear yellow key and pres 1-0-7 press and hold down more 3 sec.the Clear key (red C key)) turn OFF the machine,umplugged the cords wait 10 sec,plugg the cords amd turn ON the copier.
Aug 14, 2009 | Ricoh Aficio 1035 Copier
Call For Service message
No, it is a life of parts message. It also may not have been reset.
Try turning the machine off. press and hold. Copiers are like cars, they need things changed periodically like you would change oil and tires on your car. Its not a scam, its good service policies.
Feb 27, 2009 | Toshiba E-Studio 3511 Color Copier
The printer will not turn on.
Printer needs service or it's a problem of printer logic card.
check it to nearest service centere .
Good Luck.
Dec 08, 2008 | Epson Stylus Photo R300 InkJet Printer
Error SC 541
Try this... Press the Yellow reset botton then the number "1" then "0" then "8", don't hold them down, just push each botton once. Then hold down the "Stop/Clear" botton till the display changes to service mode, then turn the main Power Switch OFF then back On and see if it warm up.... If it dose not warm up you may have a problem with the fixing unit.... Good Luck
Sep 19, 2008 | Gestetner DSM 651 Copier
XEROX WORKCENTRE PRO 40
What code is it given? Is it trying to warm up and gets warm and then codes out???? You may have a short in your thirmister ... Try to clean the sensor it self of biult up toner. Then reinstall the thirmister and test the copier. You may have to replace the thirmister... Good Luck
May 12, 2008 | Office Equipment & Supplies
Replace or clean ink pad and reset chip
The waste ink pads in the bottom of the printer have "timed out", and the nagging message is automatically posted. To bypass the message, power the printer down, and hold down the STOP and B&W buttons on startup.
While this will (probably) remove the message, those messy little pads need to be replaced, or it'll get ugly under there. You'll probably pay about $65-$86 for an hour of tech help to clean it up. Check on line for procedures for unbolting the base and swapping out the pads; you might save yourself a little money and learn something useful about the machine!
Dec 06, 2007 | Epson Stylus RX650 All-In-One Printer
60 people viewed this question
jasbo
jasbo
