Question about Balance CP4401 PC Desktop
Unable to set resolution to 1440 x 900
I have a balance pc (desktop) with a Viewsonic 1703wb lcd monitor that supports 1440 x 900 p, but the maximum resolution I can get is 1280 x 768. Does the Intel 845GV chipset support this resolution? I've tried using Powerstrip to add the new resolution with no success. Thanks.
Eric
    Genius:
  • 1,226 Answers
eric, YOur LCD support upto 1440X900. this could be true if you use higher resolution VGA adapter in you PC.
This matter in the Video Adapter.
may this help,
melnavz
PS:
pls donot rate me if this solution donot satisfy you. However; if this help, pls rate me reasonable rating. thank you.
thanks for using fixya.
Posted on Jun 12, 2008
  • 3 Answers
Eric
I also have the same monitor and face the same problem. But the solution lies that you will have to buy a graphics card that can give out the resolution that your monitor is best made for. 1440 x 990.
Incase you really want at 1440 x 990.  buy a graphics card depending on your motherboard. (agp or pci-e).
hope this helps.
- kanaya.
Posted on May 16, 2009
    Scholar:
  • 50 Answers
Eric -
Resolution limitations are primarily determined by the video card within the system, the resolution of the LCD is secondary. First thing I would do is look through the documentation for your video card(or for your motherboard, if video is integrated within the motherboard), and see what resolutions are supported. If your system's video output can handle higher than 1280x768 output, then I would look through the user guide for the LCD. If both the video card AND the LCD support higher resolutions than 1280x768, you should download and install the most recent drivers available for your video card from its manufacturer's web site.
Hope this helps!
-thinstatic
Just purchased and installed a new ViewSonic 22" VA2231wm widescreen monitor to go with an existing Dell OptiPlex GX620 desktop computer. While attempting to get better resolution, got 'Out of...
Download: http://www.viewsonic.com/products/desktop-monitors/va2231wm.htm
You need to set your PC to the native resolution of the monitor, if it is too high, you will get out off range message: native resolution is 1920x1080p @60Hz.
You can read more here about the message:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 02, 2011 | ViewSonic VX900 19" LCD Monitor
I am attempting to use a Viewsonic VX2235wm 22 inch LCD monitor with my Alienware m11x Rx2 laptop. (4g DDR3, Core i3 520um, Windows 7 64-bit) as an extension ofn my desktop. Naturally I would like to use...
Does it do the same if you hook it up to the desk top PC?
Common problem in this VX series are due to bad DC filter caps which can cause a lot of starnge symptom, see pictures here:
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
The power supply may not be stable enough to handle higher resolution mode.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Jan 04, 2011 | ViewSonic VX2235WM Monitor
Boughtcomputer plugged in monitor and it is not fitting on the screen missing about 2 inches what do I do?
You need to set the approprite resolution for your screen. To do this do the following:
1.)Right click on the desktop and select Properties.
2.)In the settings tab you will see the resolution slider bar.
3.)In your case you want to increase the resolution, you do this by moving the bar to the right.
4.)Stop on the maximum resolution supported by your monitor, usually the one at the right most setting.
5.)Click apply to save then ok.
All done!!!
Thanks
damnor01
Nov 15, 2010 | ViewSonic VX1935wm LCD Monitor
Ihave viewsonic lcd monitor va1616w. Display card is NvidiaGEForce2 integrated GPU. The resoultion is not coming correctly
Maximum resolution on this monitor is 1366x768. Check your color depth( 16 bit, 24 bit, etc) and do not set the resolution greater or you will get unpredictable results.
Brock
Sep 16, 2010 | ViewSonic VA1616w 15 inch LCD Monitor
Upon powering up, a banner flashes OUT OF RANGE. What is the fix?
The maximum/native resolution for this display is 1024 x 768 @ 60Hz, you need to adjust your PC video resolution, it is too high right now for the Viewsonic to work. Hook up your old monitor and set the new resolution, otherwise bootup in safe mode (hit f8 key while booting up) and choose VGA support, set the new resolution, reboot.
Apr 29, 2010 | ViewSonic VA520 15" Flat Panel LCD Monitor
VG150B says out of range when I hook up to my laptop and will not display anything
This is because you haven't set it up for multmonitor. You must do that and set up for extended desktop. go to the link below and it will step you through a set up http://support.microsoft.com/kb/307873
If windows 7 thats below. support.microsoft.com/kb/976064 -
Mar 23, 2010 | ViewSonic VG150B 15" LCD Monitor
Balance CP4401 PC Desktop Logo
1,065 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
