Question about Whirlpool Duet GHW9150P Front Load Washer
F11 error Can you help me with the F11 error? I read that you once had it listed. Thank you,
  • 5,911 Answers
Click on the following link for advice on how to troubleshoot and diagnose the "F11" Error.
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
If you require further assistance, or need help in locating parts, please post back and let me know. I hope this is helpful to you.
Posted on Jun 12, 2008
HOW DO I GET TOO THE TROUBLE SHOOTING PAGE FOR A OVEN
Hello friend, thank you for your post!
I understand that you need troubleshooting steps for an "F11" error code. "F11" stands for a shorted keypad and one step for troubleshooting is to reset your range. You can reset your range by flipping the household circuit breaker off for ten minutes. If that does not help correct the "F11" code I would recommend you reach out to a professional for proper diagnosis because it could an issue with your EOC (Electronic Oven Control) or wiring harness. I hope this is helpful. -Matt
Sep 25, 2014 | Frigidaire Kitchen Ranges
F11 error code
Thank you for your post, Friend.
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree. - Z
Aug 13, 2014 | Frigidaire FGB24S5A Gas Single Oven
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Just looking for that an error f 11 means
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08.
Thank you !!
Jun 28, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3 (not HE3t) F11/dL error code
The part number for the CCU under the model number you have listed is 8182687. There is also a refurbished version of the CCU you can purchase for less (part #8182237R).
Replacement parts can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. The CCU will be listed as item 15 (15A for a refurbished version) under the "Control Panel Parts" section.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: The cheapest site I found the CCU listed (NEW) was pcappliancerepair.com. The cheapest (REFURBISHED) is searspartsdirect.com.
Mar 02, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Kenmore Elite Quiet Pak 4 front load washer. I keep getting the DL and F11 error. The door is locked and won't open and the cycle will not continue. I can hear a small clicking noise in the...
f11 eror is a serial coommunication error check the harness wirinbg tio the motor and cpu unit
check the drive system for worn part
check mcu motor the dl error fial code is for door lock error it will try to lock 6 times before error code is displayed that is the issue see repair clinic.com for help hope that helps
Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
DESTRUCTIVE RECOVERY
do not hit f11 go in to ur bois by hiting f1 delete or space bar go to a screen called save settings and restore ur bios back ntldr is net leader nd is non detected leader
Aug 29, 2008 | E-Machines eMachines Desktop PC
Thank you!!
"F09" is a "Flood Condition" error code. The following link explains this:
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
Read through the information thoroughly and verify all the recommended steps. More than likely you have a drainage issue with the drain pump as a possible culprit.
If you need to check the drain pump for obstructions, the next link explains how:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
Let me know if you require additional assistance. I hope this helps you.
PS All the fault codes are normally in a tech sheet provided by the manufacturer. This tech sheet is usually placed inside the washer behind the lower panel, or affixed to one of the interior cabinet walls.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
Error Codes F dl and F 11
Okay...it sounds like you have a bad door latch assembly. It makes contact, washer begins the wash cycle, and then after some vibration becomes unlatched and generates the "Fdl" code or "F11". "Fdl" is a door latch error, "F11" is a serial communications error to the CCU. A door latch problem can generate BOTH codes, because it has a communication link to the CCU. I would recommend replacing the door latch. You can find the part at either repairclinic.com or searspartsdirect.com. Just type in your COMPLETE model number in the Search menu and you will find a listing of all the parts. For instructions on how to replace the door latch, go to my profile and look under "Tips and Tricks". I have a write-up listed there on how to replace a door latch on a front loader. If you cannot find the information you are looking for, or have any further questions, please let me know. I hope this helps you.
Apr 16, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
200 people viewed this question
Dan Webster
Dan Webster
Sal De
