Question about Umax Computers & Internet
BIOS update Windows XP Home Edition won't boot up.  Message error says that it automatically shut down to prevent damage to computer.  Error message states that computer needs BIOS update or hard drive is full.
  • 55 Answers
1. Check your PC or motherboard manufacture for BIOS upgrade and upgrade BIOS firmware.
2. Try to start your PC in a safe mode by pressing F8 before windows starts. Then select a safe mode with or without network support.
3. If your computer starts in the safe mode, check if your hard drive is not full or close to full. If it is close to full you need to remove some data from your disk. Try to remove temporary files and clear your Recycle Bin. Restart your computer.
4. You might run low on your memory. If your PC doesn't have enough physical memory, windows is creating virtual memory by using space from your hard drive.
5. If neither solution works, try to run a "CHKDSK C: /R" from recovery console.
Good luck!!!
Posted on Jun 12, 2008
I have an Window XP 2002 operating system that is shutting down.
this has to be caused mainly due to some hardware problems or hard disk problems. try removing your bus wire the white belt you have connected with your hard disk and reconnect it again . if it doesnt work try replacing a ram for temporary to chech the problem whether its caused by ram. let me know if the problem persists.. thank u :)
Jul 13, 2010 | Microsoft Windows XP Home Edition
When I try to turn my computer on i have a blue screen message saying "A problem has been detected and windows has been shut down to prevent damage to your computer." I can't login or anything. I have even...
From your request, the question is very general.
Code Stop 0x0000007B, it means "inaccessible boot device": Windows is not able to read from the device it's supposed to be booting from. That device would normally be your hard drive - but if you're getting this during Windows installation, it could be something wrong with your CD or DVD drive..
The Stop 0x0000007B error message will be displayed on your screen with a lot of other information in what is know as the "Blue Screen Of Death" or "BSOD".
Different PCs have different "IDE or Sata interface default settings" depending on the OEM manufacturer specifications. Check your OEM motherboard require any BIOS updating.
If your PC is a desktop, remove all the PCI devices installed on the PCI slots.
If you can access to the CMOS BIOS, reset the settings to default, save the settings and reboot your computer.
If the your PC can access to windows, do a "chkdsk /f/r" from the "Command Prompt".
If not you have to reinstall the OS.
Jul 08, 2010 | Microsoft Windows XP Media Center Edition...
Compaq presario F730US frozen. Removed battery to reset system. Now boots up but get "new hardware found" error message. Now no applications functioning and error message comes back again and again. Using...
if resetting the bios does not work, you either got a nasty virus, or the hardware has an issue. my suggestion, if resetting bios is not the solution, backup your data and reinstall windows
May 13, 2010 | HP Compaq Presario F730US Notebook
Error Message while booting with blue screen
Basically this occurs by virus hit.. Now better install new operating system and never download cracks or keygens from any sites, most of them will contain virus which causes this.. and note while using pen drives too hold shift key when it is being inserted, this prevents automatic execution of virus.
Dec 28, 2009 | Microsoft Windows XP Home Edition
My Hp Pavilion dv5000 crashed! XP cd displays error message!
If you are facing this issue while installing Windows, Most probably there is an issue with the memory card. If you have two memory modules try to use one of the memory modules in each slot at a time. If you have only one memory stick then try to use it one by one on each slot. If you it does not work then probably you might have to replace the memory stick.
Hope you find this information helpful.
Thank you for choosing Fixya
Dec 22, 2009 | HP Pavilion dv5000z Notebook
I have a HP Media center pc and I tried to up date BIOS which did not work turn off my pc and then came back on with a black screen get the message need system disc put the windows xp but nothing happens
make it clear what is the exact problem weather the sys. is not turning on or it turns on but you are not able to boot if your are not able to boot what is the error and when do you get the error message.and why did you update the bios??
Oct 29, 2009 | Microsoft Windows XP Home Edition
Microsoft office professional edition 2003
check if BITS is running in the Services.msc and/or restart the Windows Automatic Update service.
Jun 25, 2008 | Microsoft Windows XP Home Edition
An error to my microsoft
Try putting the computer into safe mode.
To do this shut the computer down.
As the computer gets ready to start booting up, hold down on the F8 key.
At the menu, move the arrow keys on your keyboard to safe mode and press enter.
Once Windows finishes booting up in safe mode, restart the computer in normal mode.
This can repair the message.
Jun 13, 2008 | Microsoft Windows XP Home Edition
I cannot reformat my pc windows xp,there's an error
If you are getting an error during installation its not good :(
Its prob either yor ram or hard drive faulty. Download memtest and test ram 1st as thats the most likely cause. Check that optimised defaults are loaded in bios also.
Jan 26, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
191 people viewed this question
Top Umax Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
tdk1988
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
