Question about Motorola Mobility W375 Cellular Phone
Display ( screen) on my Sumsung mobile handset gets blank
  • 2 more comments
  • georgejuma Jul 15, 2008
    white display on screen , change the cable and lcd but no change
  • henryboyc Jul 19, 2008
    Blank screen on my motorola w375. But I can receive calls. I switched on, off. Took out battery, sim. Same problem. Help!
  • ladabam Nov 19, 2008
    my motorola w375 dont work i charged it and everything upon it just a blank screen whats with it help?
  • tarkeshwa May 12, 2009
    T.P.Singh
    My Motorola W375 wont 'wake up' and would not even blink when put on charger.
Got it! I took out the battery. From where the battery used to be, there are 4 small screws, 2 on each side. I just loosened and then tightened again the screws with the use of an eyeglass screwdriver. Return back the battery. And voila! The screen appeared. The cellphone worked fine again! Patalsikin si Gloria Macapagal Arroyo! The most corrupt fake president of the Philippines!
Posted on Jul 19, 2008
No display blank screen
hi sir. the problem is the flex wire of the display on the handset unit and this is common. you have 2 solutions. first change for a new the handset unit. or open the handset, remove the main board, separate slowly the display screen from the main unit. whit a hot air gun, give some hot to the white flex on the main board side(not too much or you can destroy that). and tighten a little with your fingers on the flex and the main board. This should paste the flex.
Nov 09, 2013 | Panasonic KX-TG5631 Cordless Phone
Philips cordless phone SE565 Second Handset not functioning it is Flashing but the screen is blank cannot get anything on it
Jan 10, 2012 | Philips Lands Phones
The display stopped working, Just a white blank screen. The phone still works but the screen does not. Can't see who is calling and can't retrieve pictures.
Hi,blank screen is usually caused by bad screen or flex depending on the type of phone you are using at the moment.
If the phone is a flex phone that means you will need to check both the screen and the flex.(flex makes the screen to display).
When you replace the screen,the phone display will be working again.
Have a nice day.
Sep 01, 2010 | Cell Phones
When phone turns on it shows blue screen. it will not do anything else. what should i do.
is the display sreen of ur phone is blank? i suppose first u should try open ur mobile handset and unplug the LCD connector and refix it .even if after that the problen persist then u should change the flex or the lcd connector. this will definately solve ur problem .
if it does then pls vote for me
thanx
Apr 25, 2010 | Sony Ericsson K770i Purple 3G Camera...
I got problem in its display i update its software 2 times but still i suffer r there software is no longer survive or sumsung mobiles r not gud
wats ur problem ..........does ur display goes blank or the screen turns off white. if this is wat u r facing then u need to change the flex that conects the display lcd with the board. this not software related issue.
if this helps you kindly vote for me
thanks
Apr 24, 2010 | Samsung SGH-J600 Cellular Phone
I dropped my phone in the toilet. It is making noises.
the display has gone in your mobile so change the display and then your settings to stop this.......
Sep 28, 2009 | Panasonic KX-TGA552M Cordless Expansion...
Blank Display
The display IC of your handset it faulty, sometimes it could be the LCD itself, but most of the time its the 25pin crystal IC. take it for a repair, tell them to try the lcd first, if that fails then its the display IC;s. BR
Jun 11, 2009 | Nokia N70 Cellular Phone
After switching on display stayed on screen and phone is unresponsive
is the handset water damaged
Michael (Mobile Phone Engineer)
Universal Mobiles Coventry LTD
May 28, 2009 | Lands Phones
Blank white screen
The problem with this handset is its data cable which connect your mobile screen to your mobile mother board. When you slide up and down, the data cable get destroyed and your screen display and sound problem get started and after some time when data cable get cuts it stop passing th current from *********** board to screen so this happen. To get resolve you need to change that data cable from service centre. But I would suggest you to go for other mobile because this is the main problem with this model of samsung . I would suggest you plz not waste your money in this handset "because of the same problem company has stopped the pruction of this handset".
Aug 26, 2008 | Samsung SGH-D840 Smartphone
Registration problem
download the user manual from the motorola web site for your model
May 27, 2017 | Motorola Mobility Lands Phones
Motorola Mobility W375 Cellular Phone Logo
182 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
