Question about Denon Audio Players & Recorders
I have a 3 year old denon avr-884 that I just pulled out of storage. When it powers up the on/standby light flashes like usual, the relays inside switch on like usual then, before it produces any sound, I hear a click and the on/standby light flashes rapidly and I get no music. Any ideas? I tried disconnecting everything from the unit and switching electrical outlets but the problem remains.
  • 1,512 Answers
Hi chris-h2o
Probably not what you wanted to hear, but it sounds like a problem in the amp. May be dry solder joint related from being moved about, or took a knock when being packed away. Check the internals for cracked PCB's and power supply and output stages for dry solder joints. If you are not big on this sort of repair work, then I could help you find someone near to you. :)
If this doesnt solve your problem, or want to talk some more about it, dont rate it yet. Just comment back to this post and we shall investigate further and resolve your problem.:).
regards
robotek
Posted on Jun 13, 2008
I have a Denon avr 2801. My standby light is flashing and i cant seem to reset it. I have tried pressing the a and b buttons together and then turning the power on, all the lights flash but thats it.
Hello
There is always a constant 5v for the device to go to standby.and power on when you press the power button .
This flashing is not to reset the device it shows that there is a problem with power supply.
the regulators are burned or over voltage ...
it needs service .
hope this helps
good luck
Jan 20, 2016 | Denon Audio Players & Recorders
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
DENON AVR 1507 short?
unplug it, let it set for about 15 min., plug it back in and see what happens. Hopefully it will recycle itself. If that fails, with your theater remote, you can pull up it's functions screen on your TV, and probably return it to factory default settings. That would be a last resort for me before seeking professional help. Good luck. . .
Jul 27, 2017 | Denon AVR-1507 Receiver
My Denon AVR-75 seems to stay in standby (red standby light is on) and I don'd get surround sound through it. How do I get it out of standby?
if the receiver does not power on from standby there is a problem like bad power supply or even bad macroprocessor. You need to bring it to a service center for diagnosing. 10-years old receiver, maybe better to buy new one.
Nov 23, 2011 | Denon AVR-75
Denon avr-1506 will turn on then flash red and turn off... how do i make it stop or fix it??
In most AV receivers if the standby light flashes after turning on and you don't hear the regular click of the relay engaging after 4 seconds, indicates an output short or amplifier failure. The protection circuit prevents any further damage by not turning on system.
You will need professional help to fix this problem because even to a electronic enthusiast the construction of a typical AVR is not service friendly.
Jul 01, 2011 | Denon AVR-1506 Receiver
My Denon AVR-1804/884 standby light stays on but the receiver wil not power up
ok my denon avr 1804 was jamming and it shut off on standby red light flashing comes on then goes back off what is wrong ?????
Feb 27, 2011 | Audio Players & Recorders
When I turn the unit on, it turns off in a few seconds. There is a flashing standby light.
Power switch relay needs replaced. Its a small black box with a clear piece that comes off, it would be hard to replace yourself.
Apr 05, 2010 | Denon AVR-1601 Receiver
Denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Mar 06, 2008 | Denon AVR-2106 Receiver
138 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
