Question about Frigidaire Ovens
Frigidaire self cleaning convection range
I was running self-clean cycle for the first atime and half way through,an error code appeared F1 and it is beeping continually.......pressing clear off doesnt help HELP
  • novakate Aug 29, 2008
    I also was running the self cleaning function. Seemed to be getting VERY hot. The keypad bubbled a bit. I pushed clear to try to halt the cleaning. It did stop- though not sure that hitting clear was the reason. Tried to use the oven after cleaning and the keypad does not respond at all. Then, it seemed to be functioning on its own - went into hold mode, tried to heat up but no temp had been entered. Finally, F11 error came on and beeping persisted. Afraid of error- we flipped the breaker to the off position.  We called service in, but the oven is only 1 1/2 years old- won't be covered by service, but it's the first time I have used the cleaning function.
  • 725 Answers
Error code F1
1. Shorted keypad.
2. Control's internal checksum may have become corrupted.
3. Control has sensed a potential runaway oven condition. Control
may have shorted relay, RTD sensor probe may have gone bad.
1. Disconnect power, wait 30 seconds and reapply power. If fault returns
upon power-up, replace EOC.
2. Check RTD sensor probe and replace if necessary. If oven is
overheating, disconnect power. If oven continues to overheat when
the power is reapplied, replace EOC. Severe overheating may require
the entire oven to be replaced, should damage be extensive.
3. Replace EOC.
Check resistance at room temperature, if less than 500 ohms, replace
Temperature (°F) Resistance (ohms)
32 ± 1.9 1000 ± 4.0
75 ± 2.5 1091 ± 5.3
250 ± 4.4 1453 ± 8.9
350 ± 5.4 1654 ± 10.8
450 ± 6.9 1852 ± 13.5
550 ± 8.2 2047 ± 15.8
650 ± 9.6 2237 ± 18.5
900 ± 13.6 2697 ± 24.4
Hope it helps please let me know
Posted on Jun 12, 2008
Fridgidaire self cleaning range: F1 error code?
You have a control board failure. First thing I would try is to unplug the range for at least 10 min. and then plug back in and see if that works. Hope that helps
May 29, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire flashing F1
Hello wills_amber - Typically, error code F1 indicates that the range has detected a runaway temperature issue (overheating). Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) on the range will need replacing.
Mar 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven displaying the f1 error code
You are experiencing a runaway temperature, or too hot of a temperature for the control board and sensors within the unit. When the unit gets this error code it shuts down for safety reasons. You would need a professional to diagnose the connections and control wiring to the control board, and the elements for safety.
Dec 30, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning oven an f1 error appears
Analog to Digital Failure
Disconnect for 30 seconds - if display reappears - replace control board
Jul 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Range Cleaning Cycle not Working
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 22, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire during cleaning F1 error,
F1 means its your electronic control and it will probably cost you the same amount to get this problem fixed again. The part is usually $350 plus.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
373 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
