Question about GE GSS25LGM Side by Side Refrigerator
Remove refride doors
I need to remove the doors on my GE side by side model # GSS25LGMB to move it to another room. HOw do I disconncet the tubing on the bottom?
    Scholar:
  • 111 Answers
By pressing the collar on the blue (or possibly grey) plastic union connector towards the center of the connector while gently pulling the water line out of the connector
Posted on Dec 16, 2008
GE side by side refrigerator freezer door water tube broken
You need to contact a seller of GE parts with the model number of your fridge and order a replacement tube, these can be a pain to fit but not too hard.
Mar 10, 2012 | Refrigerators
Water not coming from gss25lgmb bb
I have a GSH25JSRFSS GE refrigerator. Twice, the water line has frozen near the dispenser. Each time I used a hairdryer to heat either the side of the door where the water line runs and blew hot air up the dispenser. This last time, I took the plastic cover off the outside of the door (it clips on) and blew hot air into the small holes in the door that the outside grate clips into. This allows the hot air to get inside the door, and I heard ice from the frozen line drop. Subsequently, the water line worked. Two points: I did have water running to the line in the bottom of the refrigerator, so I knew it was an ice clog, and secondly, I took care not to blow hot air on the exposed wires inside the door.GKAZ
Oct 23, 2011 | GE GSH25JSRSS Stainless Steel Side by Side...
I have GE side-by-side refrigerator, model GE GSS25LGM BWW. The tube from bottom of freezer door to water dispenser is leaking. It probably got damaged during our move when we removed and door and sat it...
I am sorry no repair I know of. As a repair tech we have to change doors often due to the same waterline freezing. there is no way in without damage to door . however you can buy the door from GE for about 300-400 dollars or do without ice & water thru door. Sorry I hope this helps
Aug 18, 2011 | GE GSS25LGM Side by Side Refrigerator
I have a GE side by side refridgerator Model GSH25JSRFSS and I have ice coming through the door but the water stopped coming through the door. Any suggestions?
Greetings,
here is a quick way to tell...remove the kickplate and under the freezer door you'll see the water hose coming out the door and going behind the kickplate...there will be a quick disconnect coupling that you can release one section of tubing...do this and with the freezer door closed..Have someone push the water and see if comes out..if it does..the water hose in the door is frozen...re-install tube into coupling...if it does not come out being disconnected, then you most likely need a new water inlet valve...to remove tubing at coupling if its not a screw on one...as the tube going into the coupling there will be a plastic ring that is loose..push this into body of coupling while pulling out tubing.
Jan 21, 2011 | GE GSH25JSRSS Stainless Steel Side by Side...
Can't get temp down on refrid side
Is your fan motor on the evaporator working? If it ain't then the cold air won't go into the fresh food side.
utube.png You-Tube video "7m2XWHqr-n4&feature=player_embedded#!" placeholder PSS service Manual
More Good stuff is HERE
Jan 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge side by side model gss25qgmd bb. the water dispenser is not working. I have narrowed the trouble to the tube which enters the bottom of the freezer door and ends at the spigot in the door. I...
I had the same problem. My fix was to disconnect the tube as it enters at the bottom of the freezer door and allow room tempurature( to warm the inside of the tube) and melt the ice in the tube. It took about an hour or so and it worked.
Mitch from PA
Nov 24, 2010 | GE Refrigerators
I have GE GSS25LGMB-WW Refrerator the compressor is NOT run and I want to know where the main boar is locate?
Mine was not working either - and I found the "bullseye" mentioned above. Re-soldered and it works great!! Thanks!
Oct 06, 2010 | GE GSS25LGM Side by Side Refrigerator
Do you know of online instructions to take door off a side-by-side GE Adora refrigerator model no DSS25KSRDSS? The door has built-in conveniences so I need some specific instructions on how to disconnect...
there is a cap on the top hinge-remove it--unplug the wires. then unhook the water line from the front bottom(after turning the water supply off).first unscrew the top hinge with the door shut. open the door and lift it straight up until the water tube is free. then take the bottom hinge off.
Oct 28, 2009 | Refrigerators
I own a GE side-by-side model # GSS25LGMF CC; my water dispenser does not work but the ice maker does. I went as far as disconnecting the tube coupler under the door. I press the dispenser button and...
ive seen this before on this model, what is happening is the water line in the door is freezing and clogging up
the best thing you can doo here is disconnect that tube and try to get it defrosted
i usually suggest to turn the unit off
and open the freezer door let the inside come up to room temp
and drain from the coupler
Oct 17, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Ice/water tubing broken during move
If the tubing broke off evenly at the door , have to replace the door . G E's cant replace the tubing INSIDE the door . A used appliance store may have a door .
Aug 05, 2009 | Freezers
GE GSS25LGM Side by Side Refrigerator Logo
94 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
