Question about Samsung DVD-V8600 DVD Player/VCR
Player does not recognize that a disk has been inserted
Thanks Aaron,
I guess it would be a good idea, in any case, to clean the lens as you suggest. It has never been done in the 2 years that I have had the player. However, one other thing that makes me think it coulld have a different problem -- when it is attempting to load the disk there is a little whirring sound with a cyclic hesitatation as if something is "skipping." It suggests to me that my problem may be more mechanical- related. Is this at all possible and if so do you think it is cost-effective to try to repair it? Thanks again for your help.
Vmon
  • Riko2U Mar 11, 2009
    I had two Samsung dvd 's fail on me the same week, one on the 8600 unit and another on a multi system unit I bought for watching PAL dvd's and tapes. Samsung make ****. I will never buy their brand again, ever, for anything.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 265 Answers
Hey again vmon,
If this isn't a behavior that the DVD player has exhibited in the past, you might be looking at a potential hardware failure instead. While some noise may be expected from any optical drive (DVD player, CR-ROM, etc.), it should be fairly consistent while the drive is in operation. Any kind of unusual "skipping," buzzing or grinding noise can often be an indicator that an internal component is out of alignment, or that the rotational mechanism in the drive has encountered a problem.
As such, you might want to discontinue using the player until you've had the chance to speak directly with a repair technician. Even if internal components have suffered failures from normal usage over time, there still can often be a risk of damage to any CD/DVD media used in the player until parts can be examined or replaced.
The only drawback to seeking repairs on devices like DVD/VCR players is that in many cases repair costs may exceed the purchase price of a brand-new player. If you aren't necessarily attached to this specific model, I'd suggest checking out your local retailer for pricing and availability of possible replacements. Most retailers should carry a fairly wide variety of makes and models, generally priced anywhere from around $80.00 to upwards of $300.00.
Again, hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on Jun 12, 2008
DVD No Disk Inserted
Hi. the mother board will acknowledge a no read as (no disc) if the optical lens assembly has failed. two issue here, the tracking motor and lens have failed. you will need to replace the entire optical lens assembly in this case.
Jun 03, 2009 | Denon DVD-5900 DVD Player
Disk keeps spinning and spinning
Hey deckerfam,
If you're encountering this problem with a good number of your CD/DVD's, you may want to try cleaning the lens of the player itself before resorting to any kind of drastic repair or replacement measures. Surface contaminants can often cause optical devices such as DVD players to fail to recognize any inserted media, and are generally among the most common reasons why such a failure may occur. This type of issue can typically be resolved by using an optical drive cleaning kit which you should be able to obtain through a local retailer, but please keep in mind that using one may not necessarily solve the problem.
Additionally, some DVD players may offer a "reset" button/feature that returns the player to its original factory settings. While I was not able to locate any instructions how to do so for this specific model, you may still be able to reset the player by disconnecting it from all power sources (including the battery) for one to two minutes before reconnecting them. I’d strongly suggest referring to your owner’s manual for more information however, as reset methods can vary from model to model.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 28, 2008 | Sony DVP-FX810 Portable DVD Player
Appears not to recognize disks
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Jun 28, 2008 | GoVideo R6530 DVD Recorder
Hey vmon,
If you haven't been having any trouble previously with any of your DVD's, you may wish to consider cleaning the lens of the DVD player itself. Dust, lint and other contaminants can often prevent players from being able to read or even recognize any disc in the player.
Typically, you should be able to clean the lens by using any commercially available CD/DVD cleaning kit. Many major retailers will stock one or more type of kit, which normally resemble DVD's with tiny brushes or grooves on the bottom. These "brushes" should clean the surface of the optical drive by pushing debris away from the lens.
Should cleaning the lens not resolve the issue, there are a number of other problems that may have occurred. These problems generally include possible electrical failures or laser misalignment, and may need to be determined by a factory-authorized technician.
Remember that if you are unsure how to locate a repair technician in your area, you may always bring your player into your local Best Buy™ store for further assistance.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 11, 2008 | Samsung DVD-V8600 DVD Player/VCR
My samsung bdp1000 will not play some discs
Hey chazh,
If you have been having difficulty playing some discs in your Blu-ray player, there are a couple of things that I would suggest.
First, you may wish to try cleaning the inoperable discs using a soft, lint-free (typically microfiber) cloth. Sometimes dirt or lint can build up on the underside of a disc, preventing it from being read or recognized by an optical drive. When cleaning any disc, remember to use gentle, outward strokes from the center of the disc towards the outer edge.
Secondly, you may wish to try cleaning the Blu-ray player's lens itself. Similar to CD's and DVD's, contaminants on the lens of any optical device can prevent it from being able to read discs. Many retailers (including your local Best Buy™ store) may sell DVD cleaning kits, which can be inserted into the player much like a DVD or other media title.
Should cleaning the discs and player's lens fail to resolve the problem, you may wish to contact Samsung directly for further assistance. While dusty media may be one of the most common reasons why a disc would not play, you could also potentially be encountering format compatibility issues or even a manufacturer's defect (such as a lens that is out of alignment).
If you do not feel comfortable working with the manufacturer, remember that you may always bring your player into your local Best Buy™ store for service and repairs.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 10, 2008 | Televison & Video
XV-N40BK/XV-N44SL (NO DISK INSERTED)
Hey WeiesBlitz,
There may be a number of reasons why you may be encountering this problem, but there are a couple of quick solutions that may always try before seeking repairs on the player.
First, I would suggest making sure that the DVD's being used have been cleaned and are dust-free. Imperfections or impurities of any kind on the surface of a CD or DVD may prevent the laser in your player from being able to read, or even recognize the media inserted. You should be able to clean the DVD by using a soft and dry, lint-free (typically microfiber) cloth. Remember to try using gentle, outward strokes that run from the inner ring of the disc directly to the outer edge.
Second, you can always try cleaning the lens of the player itself using a commercial cleaning kit. Many retailers (including your local Best Buy™ store) may sell kits that clean lenses when inserted into your player like a normal DVD. Please keep in mind that not all DVD players are designed to function with these cleaning kits, and that you should always refer to your owner's manual for any possible warnings against the use of such products.
Should these suggestions fail resolve the problem, you may wish to try using other DVD's from your film library in the player. If other discs function normally, the non-functioning disc may be damaged. If using other discs results in the same error message, the player may be in need of physical repairs.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 06, 2008 | JVC XV-N40BK DVD Player
DVD player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Dec 30, 2007 | Samsung DVD-V3500 DVD Player/VCR
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
Samsung DVD-V8600 DVD Player/VCR Logo
380 people viewed this question
Jerry Greenberg
Jerry Greenberg
