Question about Craftsman 17765 Canister Wet/Dry Vacuum
Losing suction filter clean,hoses clear,output blower good,but very poor suction
  • lw269 Jun 12, 2008
    found the problem. there is another filter on the underside of the motor assy.a quick release allows you to remove assy.turn it upsidedown and remove 3 screws.remove cover and clean washable filter.reverse steps to reinstal. this fixed my problem.
  • 77 Answers
If the blower is much stronger than the suction, you may have an air leakwhere the cover fits on tank or possibly a warped tank or cover. feel all around the unit for air being drawn in somewhere besides the hose. try it without the hose on and block the inlet for a couple seconds to see if the unit leaks air in. also replace the filter , dont try to clean it, the pores clog and reduce suction and damage motor.
Posted on Jun 12, 2008
Ihave a canister vac. Bought last april low suction
Have you cleared the vacuum hoses
Dec 01, 2016 | Vacuums
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
No suction coming from the bottom of the vacuum
9 times out of 10 there is a hose blockage at the point where the hose bends down to the floor. remove the suction hose and clean and clear any dirt build up inside the hose. also at this point it is a good idea to clean the filter. ( remove and brush out or use a air compressor to blow filter clean ).
c...
Dec 31, 2010 | Vacuums
Very poor suction.No obstructions in hose.Just cleaned filter and emptied canister.
Are you getting good section at the wall inlet? If so, see below.
Check for a clog inside the power nozzle. Detach wands and drop a small coin into connection. It should fall through. If it doesn't, there's a clog that needs cleared.
A leaky hose could be the problem. Any vacuum hose is often mistreated, though intentionally. But due to the length of the CV hose, it undergoes quite a bit. Being constantly dragged around corners and pulled around, as well as improper storage can all result in holes/leaks in the hose. A few tiny holes throughout the length of the hose will result in an often dramatic loss of suction.
How old is the vacuum? It may be time to replace the hose.
Nov 22, 2010 | Electrolux Central Vacuum
No suction.
Poor suction can be caused by obstructions, poor air flow or a compomise in the air flow (hole in the hose). Since you have started with that I would next look at all filters and clean them. First check for suction at the motor, then at accessory hose and then the base. this will lead you to a suction issue. If your baelt has not been replaced in the last 6-12 mo I would change that too. check to make sure your carpet setting is coorect for the carpet being cleaned.
Oct 15, 2009 | Vacuums
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 | Vacuums
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
Craftsman 17765 Canister Wet/Dry Vacuum Logo
258 people viewed this question
Top Craftsman Vacuums Experts
Tim Doolittle
Tim Doolittle
 steve
steve
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
