Question about Kenmore 22422 Top Load Washer
Kenmoore 22442 Washer will not drain or spin
Went to do clothes th eother day and started the washer, came back an hour later and found cycle button at Spin cycle and washer full of water. Tried chnaging dial to another setting and nothing happens, so the washer can agitate, but thats it. Have since drained water out, but want to know if worth trying to fix on my own or just go get another washer? I am kinda handy, so if I can fix it, need step by step instructions please.
Thanks,
Steve
  • 6 more comments
  • Anonymous Jun 16, 2008
    I have been having the same problem. The washer got off balance, I took what was in there out and now it won't do anything. It makes no noise whatsoever, not even when I close the lid.
  • kiersauc Jun 16, 2008
    I have the same problem. The washer got off balance, I took what was in it out and now it do anything. It won't make any kind of a noise, even when I shut the lid.
  • Anonymous Jun 17, 2008
    washer will not drain, spin. will still agitate though. Found the button on lid was broken but can not figure out how to open and replace. Of course Sears no help w/out dishing out the big bucks. Anyone know how to get in there and fix the thing? Can't find our manual..
  • Anonymous Jun 18, 2008
    washer will fill and agitate but does nothing at drain time so it just stops
  • newlinvargas Jun 21, 2008
    washer wint drain
  • learjet1 Jun 23, 2008
    I have the same problem and a friend who is a former repairman for Sears said 99 out of a 100, it's the lid switch. It should make a clicking noise when ingaged.
  • 61538 Jun 27, 2008
    yes, I have the same problem. thanks 61538
  • Toby Norton
    Toby Norton May 11, 2010
    Does your lid make a click sound when the lid is closed? You may have a bad/ loose lid switch. Does it make any noise when you start the machine on spin? The other posibility is a bad timer but get back to me with the other 2 questions before we go there. :)
  • 246 Answers
We have not heard back on this in about a week. I'm presuming It's been repaired?
Posted on Jun 21, 2008
I'm having the same problem with mine. Did you replace the lid switch or timer?
Posted on Jun 15, 2008
Wont drain
First Try Unplugging the washer for 15 minutes. Sounds like the pump is the issue. Was it a normal load of clothes or a Bath rug or blanket?After you plug the unit in try to select rinse/drain Or drain/spin.
If it starts try to cancel the cycle. The washer should drain the water out for you. Pls update when you can.
Sep 01, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 90 Series, year 2000 Came back to put clothes in dryer and found that the clothes were still wet, not spun wet, but wet where I could wring water out of them. I hear the motor running, and the...
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
Spin cycle not working properly, clothes still wet!!!!
Motor coupler Totest the motor coupler, re-start the washer in its spin cycle. Let themachine run for a minute, and then open the lid and notice whether thetub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • Ifit isn't spinning--and your machine was produced by Whirlpool®--you mayhave a broken coupler. Many Whirlpool-made washers use a small,relatively inexpensive device called a motor coupling. Thisplastic-and-rubber component is mounted to the shaft of the motor onone side, and to the transmission on the other. Over time, the couplerwears out and fails. When that happens, you need to replace itcompletely.
Spin cycle Ifthe washer doesn't reach its proper spin speed, the clothes may be toowet at the end of a cycle. Check to be sure the load is properlybalanced and run a spin cycle again. If the clothes are still wet, youmay have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®),or a worn motor pulley or tub bearing. Replace the applicablecomponent.
Alternatively, there could be clothes caughtbetween the inner and outer tubs. Read the "It spins but won't pump"section of the "It won't drain" section. Also, there could be otherthings that cause friction on the drive train. Seek the assistance of aqualified appliance repair technician.
Siphoning Ifthe water that pumps from the machine goes right back into the machineafter the spin cycle, it may be because your washer is siphoning thewater from a laundry tub with a slow drain, back into the washer. Tryto improve the draining of the laundry tub. (Is there something stuckin the drain?) Also, be sure the drain hose doesn't reach more thanabout 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inletvalves eventually fail. One problem that may develop with a water-inletvalve is that it can no longer completely shut off when the electricityis turned off to it. Then, the valve may leak and drip water into theclothes tub--you may notice that your washer has water in it when youhaven't used it for a few days. To fix this, replace the valve.
More information can be found here:
http://www.repairclinic.com/0088_11_1.asp#Level1_12
Oct 29, 2008 | Kenmore 24032\24036 Top Load Washer
GE Front load washer WCHVH 6260F
I had the same problem.....The start/pause button would flash during a cycle and the washer would not finish the cycle. After reading on this forum that there is a filter/strainer inline with the drain, I tried this solution.
Remove the (3) screws that hold the lower front panel (Just below the door)
Once the panel is removed, you should see a white plastic strainer hooked to the washer drain.
Please a large bowl under the opening and unscrew the knob/handle, pull the filter/strainer out and clean all of the lint/trash out of this area.
My filter/strainer was clogged with a baby sock, 2 doilies, a fewe pennies, 2 dimes and lot's of lint.
I believe all of this debris was causing musty odors in the machine as the lint would stink due to dampness.
Once I cleared out this filter/strainer the problem and my odors went away
I wish GE would add this "EASY" step into the owners manual for proper care and maintenace.
Thank you for letting me know about this filter/strainer as it did resolve my problem
Sep 13, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore 22442 not spinning unless you physically help it along
Sounds like a worn belt problem!
Call service now before it gets worse and cost you a lot more money!
You'll be okay!
Electronic problem. just call service.
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Give me a good rating on this site , FIXYA.COM
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Aug 23, 2008 | Kenmore 22442 Top Load Washer
Kenmore 22422 Top Load Washer Logo
64 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
