Question about Lakewood MTF-15 MiniTower Fan
Lakewood Model 3364 Tower Fan
My tower fan is less than two months old and yesterday it stopped oscillating for no reason. The rest of the fan is working just fine. Please help
  • 2 more comments
  • Anonymous Jul 26, 2008
    Im having the smae problem after a week.. any suggestions would be great
  • jgeiman Aug 13, 2008
    My fan stopped oscillating after three days use! I've e-mailed Lakewood Customer Service asking for assistance. If they don't respond, I am going to return this fan to Wal-Mart for a refund.
  • deziroo Sep 10, 2008
    my fan is 1 week old, and the power wont even come on!!! I have tried switching plugs, ive left it unplugged then plugged it back in. My outlet is fine... So i want to know if there is anything i can do, otherwise ill take it back
  • kc47 Nov 20, 2008
    After my 1st Lakewood tower fan kept turning off for now reason within a few weeks of purchasing it, the 2nd one I got from Lowe's stopped oscillating within the first 48 Hours! What a piece of junk! Thank god for a return policy.
Buffalo12980
  • 625 Answers
SOURCE: I am trying to fix an Oscillating Tower Fan.
Most fan motors for fan over running have an internal overload. once it trips, it will not reset. it is a solid state device. it looks like a flat device or a small bullet device. if you've figured out how to take the fan apart, you could just remove the device and connect the two wires together and the fan will run. you won't have any protection on the motor however. the windings run warm, but if the bearings run dry the motor will slow down and the windings will get hot. this is the reason for the overlaod device - protection. its your call what you want to have.
Posted on Sep 05, 2007
SOURCE: how do you open up a BDTF101B Tower Fan?
first you have to remove the two plugs on top behind the buttons remove the two screws next you have to remove the base stand and their is one screw you have to remove then you can remove the front cover and you can get to the motor and fan.
Posted on Jul 12, 2008
SOURCE: LASKO fan problem
Check for a loose wire in the wiring harness
Posted on Sep 04, 2008
  • 40 Answers
SOURCE: Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Posted on Jun 28, 2009
  • 6 Answers
SOURCE: FTT-R tower fan would oscillate but the fan would not run.
You might have a stripped gear in the tower where it oscillates. Hope this helps!
Posted on Jul 14, 2009
Tower fan stf-31s not blowing
The blades are probably covered in dust. Mine does this when it needs cleaning
Aug 06, 2016 | Tower Dryers
I have a 42" wind
the first thing to check is that the remote control is working and the control panel of the fan itself are working probably and i think they did but you have to check first
this fan oscillating control button is not a mechanical connection like the regular fan so if you are not using it wrong(and i think you don`t ) an if all the buttons are working -except the oscillating function - (and i think they are ) turn that thing back and test it at the shop
May 22, 2011 | Lasko 42" Wind Curve Fresh Air Ionizer Fan...
When computer sitting unused and then mouse is
The humming might came from the exhaust fan inside the power supply or the exhaust fan of the tower housing case of your desktop, there must be some loose screw, also check the Processor fan.
Jan 28, 2010 | HP Pavilion Elite d5000t ATX Customizable...
I have the Viking Emerald 118 model, less than a month old. I cannot get the button for setting whether the needle stops up or down to work. It worked fine the last time I used my machine. I also am having...
The large wheel on the side of the machine that pulls out to thread a bobbin is probably pulled out. Push it in and the rest of the features should work.
Jul 15, 2009 | Sewing Machines
Jul 14, 2009 | Black & Decker BDTF1010B Tower Fan
Jun 28, 2009 | Tower Aloha Breeze Fan
Aloha Breeze Tower Fan Will Not Oscillate
hi,
yes this is the oscillation motor, and they generally arent servicable, and need to be replaced, you can try and oil it, sometimes they have small air vents, and you can do a voltage test with a voltmeter but I believe the motor has failed or is gummed up, you can try and take it apart, they are held together with bent metal compression areas along the circumfrence of the motor, try sewing machine oil, you might have to do some research to find a replacement motor, maybe take it to a local clock shop, those motors are very close to what they used to put in old wall clocks.
good luck
J
Aug 05, 2008 | Tower Aloha Breeze Fan
How do you open up a BDTF101B Tower Fan?
May 29, 2008 | Black & Decker BDTF1010B Tower Fan
I have a Honeywell oscillating quiet cooling tower fan that was bought two years ago. Loved it, till yesterday it just stopped working. the oscillating feature still moves, but the fan does nothing. the...
Could be fixable but until someone determines the problem there is no way of knowing if it is fixable. Could be a broken wire between the selector switch and the motor or the motor itself could be bad.
When you are trying to operate it does the fan motor get warm or hot? Does the fan turn freely?
May 03, 2008 | Heating & Cooling
LASKO fan problem
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
Lakewood MTF-15 MiniTower Fan Logo
722 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
