Question about Mintek MDP-1810 Portable DVD Player
Freezes while playing
I insert a dvd and it starts playing. Then about 15 minutes into the movie, the system completely freezes and I have to turn it off. What is causing this problem and how do I fix it?
  • aleutiamoon Mar 07, 2009
    It freezes . . . then jumps to any random place.
    Genius:
  • 1,139 Answers
Hello bnycenice,
I posted this a while ago, but I think it applies to your problem:
You can try a cleaning disk, however it has been my experience that the cleaning disk will not help, but it is a good place to start from. More then likely it is a problem with the laser pickup photo-transistor, these often malfunction causing this problem. I would suggest if you are going to try to repair this yourself, you will need a multimeter, a laser meter, and a schematic. The first step is to measure the laser energy leaving the laser diode and see if it matches the specifications in the schematic, if it does not, check the bias voltage with the multimeter, this is to determine if the problem is the bias voltage or the diode itself. If the diode is bad replace it. if the diode is good then the pickup becomes suspect. Using the multimeter measure the bias voltage on the photo-transistor with and without the presence of the laser light from the diode. This will tell you if the photo-transistor is good or bad, if the transistor is bad replace it , if it is good check the components that make up the biasing circuitry.
Now This test will produce a test of go or no-go on the laser diode and the photo-transistor. One of these components or their related biasing circuitry is either bad or about to go bad, by testing the voltages and laser light levels you should be able to determine which one or if both have a problem.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 08, 2008
Picture freeze,long tme to restart does it again
Unless you have good / fast access to the Internet (or wireless or 4G network), it may take a long time to download a movie to your device. If the speed of download is slower than the speed of the play, the picture freezes ... essentially, it is waiting for the completion of the download for the next few frames (of the movie). That is why the picture freeze .... and it will start again after sufficient data has been download to continue / start playing (the movie) again.
Apr 30, 2013 | Cricket Wireless Cricket Crosswave WiFi...
System will not play DVD's. Sometime it will play for about a minute or two and stop. Sometime it will play and the picture freezes. Sometime it act like it wants to play but never does. Can you tell me...
Troubleshooting Solution
  1. Lift disk changer doesn't work comes message "Disk Error"
  2. Lift disk changer work fine but doesn't load a DVD
  3. Power light is ON but doesn't want to Power UP
  4. From the beginning start DVD movie the picture distorted and freeze
available parts avsystemparts.com
1. Possible Problem w/ Main Board PCB
2. The dive laser assy replace. or full complete 5 Disk changer ROM
3.More chance problem w/ Main Board
4. Problem w/Main board need replace it.
Feb 20, 2011 | LG LHT874 Theater System
Recorded DVD disc freezes up on a different DVD player
hey ,
recommendation, the disc may have an internal scratch. (meaning when its played there might be a bump or something on it unseen by the human eye)
or you can stop being cheap. and get a new one
Jan 20, 2009 | Universal Music and Video Distribution...
I recorded a DVD on dual layer DVD
the size of the movie in terms of gb?
may be after writing first layer of the dvd, while going to 2nd layer problem starts
Jul 16, 2008 | Electronics - Others
Computer freezes
hi
can you give more information on which program you're using for playing DVD movie ??
takecare.
May 23, 2008 | HP Pavilion zd8000 Notebook
Dvd player just freezes and wont do anything
I suggest the garbage can. I bought my husband the DVDR05 and it has not worked from day one. It will play about 15 minutes and then freeze up. We have read the book to see if it was something we did wrong. We finally shut off the tv and turned the player on before turning the tv on and we got half way through a movie that way. It is very upsetting.
Apr 22, 2008 | Yamaha DV-S5350 DVD Player
Dvd burner no worky.
Disconnect completely your driver and do the connection again from stratch! May work ! REG clean and Verify Disc before reinstalling! Good luck!
Nov 06, 2007 | LG GSA-H22N DVD±RW Dual Layer Burner
Movie freezes
Grease the slide rails with a little smudge of vaseline - especially if the mechanism is noisy. There is another reason for it that I have not worked out, but on 2 machines the grease did the trick.
Jan 18, 2007 | Polaroid PDV-0700 Portable DVD Player
Freezing
Probably needs either a cleaning or a new laser picup assembly
Dec 19, 2006 | RCA ® 700 Watt Home Theatre In A Box...
Mintek MDP-1810 Portable DVD Player Logo
112 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
