Question about EliteGroup P4VMM2 Motherboard
Beep 8 time
I have a pv4mm2 motherboard. I change my CPU and i start the computer and came very slow ! after the search of périphical he stop and begin to beep 8 time ! i want some answer please ! thanx
  • 114 Answers
The RAM is bad or is not inserted all the way. Try pushing the RAM in or replacing the RAM. that should fix the problem. Please rate my solution.
Posted on Jun 11, 2008
CONTINUOUS BEEP SOUND DURING BOOT
The beep sound is sometimes an indication of the successful boot. But, if the beep is continuous, it usually means a memory problem. I*t could be a failing ram stick or a failing memory cache on the cpu. Try substituting the ram sticks one at a time to eliminate each one.
Aug 02, 2012 | Intel Computers & Internet
P4M800Pro Intel Pentium 4
Sounds pretty much like a motherboard problem. The problem you describe sounds like a RAM problem, probably they are loose in the slot or not snuggled properly. However, since you seem sure its not the RAM, I would consider replacing the motherboard.
Sep 30, 2009 | Biostar P4M800-M7A Motherboard
Led pwr+hd isn on, cpu fan is runing, but no
if your monitor is working properlly,then you should check the following things:-Remove ram and start the computer. If it gives you any beep then your motherboard is all right.And if not,then it's time to buy a new motherboard.
Mar 17, 2009 | Gigabyte GA-8I848P-G Motherboard
Dg31 pr motherboard problem
Does it show the correct CPU speed under My computer? Did you go through the BIOS setup screen and set everything up? Are you ram chips a matched set?
Jan 18, 2009 | Intel DG31PR Motherboard
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
Jan 07, 2009 | ASUS P5VDC-X Motherboard
Asrock P4i45gv motherboard problem
it sounds as though your cmos chip is damaged; if you are unable to get as far as the bios when pressing F2 or Del on boot up, then you may need to replace the motherboard. Also reseat your memory as that is another cause and check the Cr2032 cmos disc shaped battery as this may be flat and the original cause of constant reboot cycle. Lastly this also happens if you have changed any hardwre in your pc as windows will not boot if there have been major changes to hardware and windows will have to be repaired using your XPcdrom.
Aug 22, 2007 | Asrock P4I45GV R5 Motherboard
EliteGroup P4VMM2 Motherboard Logo
65 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
