Question about Toshiba 24AF43 24" TV
Rows of Lines across top of screen
There are rows of lines running across the top of the screen equaling about 2 inches in depth.
  • sirdollarbil Nov 02, 2008
    I have a Toshiba 24af43 and all of a sudden I have lines across top of screen.
  • humanbacteri Mar 01, 2009
    i have the same prob., about 2" acroos the top of the screen. at first it would come and go when turned on. its starting to grow 1/2'' increments.
    humanbacteriafrappe1@gmail.com
I decided not to repair, but use the 16:9 feature on the remote control.
a kind of letterbox look, not bad at all.
I'n not going to spend money, replacing the vertical output ic circuit's bad capacitor or vertical power supply for bad cap.
Posted on Apr 12, 2009
How much area will be covered with 36.78 cubic feet of mulch please answer in feet and inches
How it Works
Stone and Mulch Calculators
As an example, let's use 500 square feet to be mulched at a
3" depth.
  1. First, the depth must be converted to feet. To convert inches to feet, simply divide inches by 12, the number of inches in a foot.
    So for our example: 3 inches divided by 12 equals a 0.25 foot depth.
  2. Now that we have the depth in feet, we can multiply the depth by the area.
    So for our example: 0.25 foot depth times 500 square feet equals 125 cubic feet.
  3. If you are calculating 0.5, 2, or 3, cubic foot bags, simply divide 125 cubic feet by the size of the bag.
    So for our example: if we are using 2 cubic foot bags, we can divide 125 cubic feet by 2 which equals 62.5 bags.
  4. If you are calculating cubic yards, we need to convert 125 cubic feet to cubic yards by dividing by 27. One cubic yard is equal to 27 cubic feet, see the diagram below.
    So for our example: 125 cubic feet divided by 27 equals 4.63 cubic yards.
For Your Information
  • 1 inch equals 0.08333 feet
  • 1.5 inches equals 0.125 feet
  • 2 inc
Jun 29, 2016 | Office Equipment & Supplies
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
My screen has blue and red lines across it. Now the red lines are becoming stronger and the screen flashes red until it turns off. how do i fix this?
This is for if the lines are thin and in the form of an arc across the screen.
You need to turn down the screen voltage for the blue and red CRT. I believe the access is through the front on that model.
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
Model# kdl-40w4100 Serial # 8051767 2 years old Horizontal lines in 4.5 inch blocks at the top of the screen
I have the same tv model KDL-40W4100 and around the same age. At the moment I have 16 of
these horizontal lines over the entire screen and they seem to be grouped into 2 lines per row. They are also around 4 inches and two pixel rows high. I have been looking over the Internet for months and found nothing to troubleshooting this issues. In the last few weeks more and more of these groups of lines have been showing up and now i am up to 16 of them and it is becoming unwatchable. Any help from anyone would be greatly appreciated. I also attached a picture to describe it better. Thanks!
Nov 06, 2010 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Toshiba 24AF43 24" TV Logo
140 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
