Question about Lexmark Office Equipment & Supplies
Ive been trying to hook up my Z35 to my Windows XP for 2 days. I only have the install disk to my Z31, because I moved and it is misplaced somewhere. I tried pointing the printer to the led on my laptop but it didn't work. Can you tell me what to do? Thank You, Sharon Parker
  • 24 Answers
Assuming that you have everything installed and connected properly (print cartridges, USB cable, etc..) all you should have to do is install the correct drivers and off you go. The correct drivers can be found at:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:338:0:0&searchLang=en&os_group=WinXP&target=
and the manual can be found at:
www.lexmark.com/publications/pdfs/z25-z35/eng/ensetupb.pdf
You will need acrobat installed to view the manual. Acrobat can be downloaded from Adobe (www.adobe.com)
Posted on Jun 11, 2008
Hello, ive just bought a brand new motherboard (GS7610 ULTRA) and i have installed it into my case with all my components and when i go to start my computer up, it goes pasted the boot menu and then i get...
Are you trying to install this OS (Operating System) , or is it already installed on a hard drive?
If you are installing it, make sure you change the boot order to the optical drive (DVD drive). If it's already installed, was it installed with an OEM disk? If yes, then you might need a new Windows XP disc. This is because, when using an OEM disc, if you change the hard drive or motherboard, it doesn't really work.
Sep 24, 2011 | EliteGroup GS7610 ULTRA Motherboard
I have an old Gateway desktop with Windows XP Media Center. The computer tries to boot but gets in a loop - will not even boot in safe mode. During a move I've misplaced my original Windows disk. I tried...
Hello there!
You'll need to try with an original CD or a copy of it. You can borrow one from a friend provided you use your own License please.
The XP CD you are trying to use is a counterfeit version & won't accept your original key.
Well I hope you get the original. please send us your votes & feedback to help us provide you a better service. Good luck friend!
Feb 27, 2010 | Microsoft Windows XP Professional With...
Hi i got gx270 and i made a bootable acronis disk director on a flash so i can format ntfs to fat 32 as i tried before to install win xp from a flash drive but got a stop message sayin i should check...
First of all I have to ask why you are trying to load FAT32 instead of NTFS. NTFS is the preferred file system for all Operating Systems after Windows 2000. Also, you cannot format the hard drive through the Windows XP installation for larger than a 32 GB partition. If you need a larger partition, I suggest using a floppy drive with the3 WinME bootdisk loaded on it. You can get it here:
Try the WinMe bootdisk from http://www.bootdisk.com/bootdisk.htm
If the above is not the issue than we can move forward with other solutions.
Good Luck,
NOLA Tech
Jan 29, 2010 | Dell OptiPlex GX270 PC Desktop
Misplaced disc for downloading webcam
If you have Windows XP or Vista, you shouldn't need the disk. Just plug in the webcam and the driver should be installed automatically.
Apr 10, 2009 | Logitech Webcam
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
Lost my disk and i need help on how to install my lexmark z25/z35 dc to my laptop
I am not 100% sure what OS you are running so I will assume it is Windows XP. You can find the link to download the Windows XP driver from the following locaiton:
http://downloads.lexmark.com:80/perl/downloads/downloads.cgi?os_used=Windows%20XP&mode=OS&ccs=229:1:0:337:0:0
Once you go to this location, you will see two print drivers to download. you will want to download the Custom Driver. Install the driver and then plug in the printer.
Feb 28, 2009 | Lexmark JetPrinter Z25 InkJet Color...
INSTALL A LEXMARK PRINTER WITHOUT THE DISK
Lexmark usually does not distribute replacement install disk.
Contact Lexmark here, to see if the disk is available.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthe file,doubleclick on the file, if you get introubles ,thenfollowinstructions below to reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Note:some printer does not work on Vista
Oct 06, 2008 | Lexmark Color Z35 InkJet
No memory on my windows xp
If the drive properties in show a full drive, then the install of xp probably has taken most or all of the hard drive space.
According to http://www.microsoft.com/middleeast/windows/windowsxp/home/evaluation/sysreqs.aspx
the operating system needs at least 1.5G.
Thanks
Aug 28, 2008 | Computers & Internet
Lexmark z25 drivers for windows vista
hi!
i followed this one:
"I was only able to print by doing the following change on Control Panel.
1. Lexmark Z25 printer Properties
2. Ports tab
3. Select USB00x instead of LPT1"
and it worked!!! problem solved for lexmark z35. ü
Nov 21, 2007 | Lexmark JetPrinter Z25 InkJet Color...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
