Question about Belkin Computers & Internet
Cant connect to wireless network set up in my home. will connect for a few seconds and then say that I cant be logged on to the network
  • 49 Answers
Try going to the manufacturers website and find out how to access your router. Then try disabling your hardware firewall. You can also reset your modem and unplug all connections for about 10 secs and then do it again. I had that problem with a linksys router and I would get booted all of the time.
Posted on Jun 12, 2008
Will not stay connected to home wifi
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
I hope that helps will-not-stay-connected-home-wifi-5x01jctu1hti52f1zciidmg3-3-0.png
Mar 19, 2014 | Samsung GALAXY S4
Tip
How to Set up WiFi Using your iPod Touch & Droid
<p>Modern mobile devices such as Android-powered smartphone Droid or Apple iPod Touch portable media device seem to do your best if you connect to the Internet. You can download new information, the browsers can surf the web and online applications can enjoy the full functionality. Setting up a WiFi connection on any device will allow full access to the Internet via a wireless network. Both devices have the possibility of links built into their operating systems to configure. <br /> <p><br /> <p>IPod Touch <br /> <p>1. Select "Settings" on the front. <br /> <p><br /> <p>2. Select "Wi-Fi and wait a moment as iPod touch detects WiFi networks nearby. <br /> <p><br /> <p>3. Select your WiFi network from the list when you get home, or a WiFi network around when you are away from home. <br /> <p><br /> <p>4. Enter any encryption keys or passwords required to log on the network and the iPod Touch can take a few moments to connect. <br /> <p><br /> <p>5. Look for the WiFi icon in the status bar at the top. It looks like an inverted triangle with a rounded tip, composed of multiple curved horizontal lines. If this icon is present, you are connected to the network. If not, try connecting again or select another network. <br /> <p><br /> <p>Droid <br /> <p>1. Tap the menu button at the bottom and select Settings. <br /> <p><br /> <p>2. Select "Wireless & Networking," then "Wi-Fi settings" and leave the droid few minutes at a nearby WiFi network available. <br /> <p><br /> <p>3. Select your WiFi network from the list when you get home, or a WiFi network around when you are away from home. <br /> <p><br /> <p>4. Enter any encryption keys or passwords required to log on the network and the iPod Touch can take a few moments to connect. <br /> <p><br /> <p>5. Look for the WiFi icon in the status bar at the top. Dot appears with several curves, horizontal lines radiating. If this icon is present, you are connected to the network. If not, try connecting again or select another network. <br />
on Jul 21, 2011 | Computers & Internet
Get stuck changing net settings, ie ssid...
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration2_bing.gif"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you other wirelss access point for you home network and some other near your home along with few information such as SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) SECURITY (this is the password you set up your network with) SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network will probably not do you any good since it'll probably be all locked with password and such and so should yours be.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING2_bing.gif page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network security setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
May 19, 2010 | Sony Playstation 3 (PS3) Console
Cant connect wirelessly as i cant locate AOSS button
AOSS is what you would see on some high end routers. if your router doesn't support this method or have this button you can't set up your ps3 using it.
The PS3 does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set devices up in this manner.
1)To use this set up for the PS3 go to Settings>Network Settings> Internet Connection Setting> (Method) Custom> (Select Connection Method) Wireless- (WLAN2_bing.gif Setting) Auto - AOSS. At this point the PS3 will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop.
Again this only works if your router has this button. and it is not found on your ps3
so you'll need to set it up differently. if your home is set up with wireless router and your computers are connected online wirelessly read along....
1) go to Settings
2) Network Settings
4) easy *it may or may not give you a message reading "checking network configuration"
5) wireless
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password yours may be different so choose the one that you used.
May 18, 2010 | Sony Playstation 3 (PS3) Console
Forgot password to log on for my wireless connection trying to add my Wii and now cant even get my laptop back online
You can check the passphrase when you access the router page:
  • Open a Web browser and type http://gateway.2wire.net or http://192.168.1.254; the 2Wire Home page opens.
  • Click the Home Networking tab at the top of the 2Wire Home page.
  • Click on Wireless Settings. then click EDIT SETTINGS located on the right panel.
  • Here you will be able to fine the setting for your wireless connection
  • You can change the SSID, Wireless Channel, Wireless Security, and Network Key
  • If the Wireless Security Key uses the default, the Passphrase is the 10 digits located underneath the router under the S/N.
Thanks for using Fixya.
May 13, 2010 | Computers & Internet
Home networking Windows XP
Often this is a simple power management issue. On the laptop check the wireless properties and disable allow Windows to turn off this device to save power.
Apr 05, 2009 | Microsoft Windows XP Professional
My laptop wont connect wireless thru linksys anymore
Reset the router using the little reset button on the back. (Hold for a few seconds) It should be able to connect using default settings. Then you can log on and configure it with your router. Go to http://192.168.1.1 and you can set up your security and port forwarding if needed. (I recommend WPA or WPA2 for security, as I have cracked WEP passwords myself using brute force.) Let me know how this works out. If it doesn't work, I need more info such as your wireless network card model.
Apr 03, 2009 | Linksys Wireless-G WRT54G Router
Forgotten network key to log on to secured wireless g router
Password recovery isn't really possible. Pushing the rest button in the back for a few seconds will reset the router to factory defaults. You will need to reset all the wireless security and such so best to do this with a pc connected directly to it. Default IP for it if you have changed it is 192.168.2.1.
Dec 26, 2008 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Acer aspire will not connect to wireless network
Does your home router have a password? The only thing I can think of doing is removing all the preferred access points from your wireless card's utility or windows (located at start => Setting => Net connections => Wireless => Wireless Networks.
Then add your home access point back.
Aug 20, 2008 | Computers & Internet
Ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Jan 10, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
29 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
