Question about Craftsman 17762 Wet/Dry Vacuum
RE:removeal of filter
I can't get the filter of of my sears wet/vac i don't have the instructions of course and I need to be able to remove it it smells moldy and I need to purchase a new one. HELP
  • 77 Answers
Some filters just pull straight off, while others have a large plastic knob that unscrews to remove the filter. if it is a foam filter, it is just a stretch fit and pulls off, though it usually tears.
J
Posted on Jun 12, 2008
How do I remove the filter from a Rigid 4 gal portable wet/dry vac
James the attached link/video shows filter just pulls off. I also put a link to the manual and it show the filter held on with large plastic nut, which would have to be removed first.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
4 Gallon Portable Wet Dry Vac
http://www.ridgidparts.com/pdf/WD40500.pdf
Rigid WD4070 Wet Dry Shopvac Unboxing and Overview
RIDGID Shop Vac Review must have tool 2
Apr 30, 2016 | Filter Vacuums
Do I remove the foam filter when using as a wet vacuum/
No, just paper filter or round cartridge, whatever is on there. Foam only for wet vac.
Jul 23, 2011 | Black & Decker UV200 Wet/Dry Vacuum
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
I have a 6 gall wet dry shop vac bye rigid . do i need a foam wet filter on the inside or will it work properly without the filter on i need it for water only. people in the store said the paper filter was...
Always use the foam filter when using the Shop Vac, keep your filters clean and it will operate more smoothly. When sucking water I usually take the foam filter off as well as the cylinder filter
Oct 02, 2017 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Should I remove the filter when using it as a wet vac. I t does not seem to have much suction.
Absolutely remove the filter for wet vac. Also, if your present filter got wet replace it as the pores are now clogged and you can't save it. J.
Jul 08, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
What if i use my wet dry vac to pick up water without a filter
DO NOT USE A FILTER WHEN PICKING UP WATER!!!!!
Im certain if you check the instruction manual it says to remove the filter.
Oct 13, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Wet/Dry Vac Leaking
are you using a water , foam material filter?
Aug 01, 2009 | Craftsman 17762 Wet/Dry Vacuum
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Craftsman 17762 Wet/Dry Vacuum Logo
155 people viewed this question
Top Craftsman Vacuums Experts
downhille
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
