Question about JVC AV-27D302 27" TV
Flashing On Timer
During thunderstorm TV went shut off. Reset circuit breaker now On Timer is blinking. Now what could it be? I've had this TV for awhile and I don't like those new plasma tv. So what can I do ?
  • Leslieunion Jun 16, 2008
    I have the same problem, an older JVC that has been wonderful but is not totally unresponsive.  i can't the tv to turn on or off, the remote control does nothing and the timer light is blinking.  I'll try to contact customer service about this;
  • mike13579024 Jul 03, 2008
    Same problem with 32 inch JVC Series D. Thunderstorm. Now the power light blinks. Unresponsive except for about the first three seconds after being plugged in, when you can turn the unit off, either using the remote or the button on the main console. Can also turn the TV back on (by either method -- remote or console button), and again off within the first three seconds. After longer than that, the power light starts blinking and the unit becomes completely unresponsive, even to the off button on the console. Only way to turn it off is to unplug it. After plugging it back in, same thing -- responsive for only about the first three seconds. (By "responsive" I mean only to being turned off. No picture or sound or response to the Menu button or changing channels.)
    I took off the back cover and checked the fuse which was OK. I just read on another post that there's another fuse somewhere, but I didn't see it. Guess I'll have to take the back cover off again and have another look.
    Genius:
  • JVC Master
  • 1,689 Answers
This is usually an indication for a scan failure, and or high voltage failure. Also, the power supply may be damaged.
Depending on the nature of the failure, this type of service can be sort of expensive. I sugget to get an estimate before deciding.
Jerry G.
Posted on Jul 12, 2008
Sanyo TV Mod# DS3225, TV lost all power during thunderstorm, is there a reset button or breaker?
short andwer NO! You coulod try unplugging it for about 12 or even 24 ghours to see if it will hard reset.
However if you don't have spike arrestor circuit then it's possible that the power supply has beeen spiked and died. Not a matter of replacing the power supply either as other damage is always done in these situations.
Better to have it proifessionally fixed.
Please rate my help++++Thanks for using FIXYA
May 23, 2010 | Televison & Video
My cable went out during a thunderstorm. The
if it is new it should be under warranty,if not ,yes there may be a fuse inside,on the board where the plug is connected,taking it apart will void the warranty and can be dangerous .dont try this unless you have experience
Sep 21, 2009 | Televison & Video
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
The timer on button flashes
The timer light blinking indicates a failure in the TV set. Either the vertical circuit or horizontal circuit has failed and needs repair. It actually has nothing to do with the timer circuit.
In my experience its probably a vertical output chip, smalla capacitor and zener diode. There may also be an open resistor.
Cost to repair in the 50-75 dollar range usually
Feb 24, 2009 | JVC AV-27020 TV
I have a sony wega
Generally speaking whent he set shuts itself down, the standby light will blink a code. This will be a count followed by a short pause and then the count again etc.
When teh set shuts down, count the blinks and post it here. That will indicate the circuit that has the problem.
Dan
Dec 05, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
On Timer Blinking TV won't come on
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jun 24, 2008 | JVC AV-27F802 27" TV
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
JVC AV-27D302 27" TV Logo
50 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
