Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Corrupted disk the system is corropted i tryed the run comand and typed the information in it and it said idt could not open dthe hard drive the drive i have is the 500 gd. is it posible to send this drive to maxtor for repair or for more information please
  • stevened Jul 13, 2008
    I have a similar problem in that my PC says the file for the 3200 device is corrupted and not accessible.
    Champion:
  • 208 Answers
If you send it to maxtor say bye bye to your data.
try runing diskmgmt.msc and assign it a drive letter.
Posted on Aug 01, 2008
When sandisk canect to system it show usbdiwais is not recosnaised
You have a corrupt malware in you usb try it in windows start then run here you put it cmd comand then apear One screen on black in the cursor you got to put it comands attrib -r -s -h -a if you usb is E or F put it Leter al the end ejem attrib -r -s -h -a E: *.* and solved the problem then you go to panel control to carpet options then Able carpet propieties then able see all ocult archives now close all and go to my pc and see you usb drive information marked just like ocult open these carpets and ready can see all your info sorry for inghlis Ips !
Jan 22, 2014 | SanDisk Electronics - Others
Tip
Chkdsk.exe
check hard disk health
Check Disk - check and repair disk problems
goi to run type cmd in run, open cmd as administrator
TYPE
CHKDSK [drive:][[path]filename] [/F] [/V] [/R] [/L[:size]]
Key
[drive:] The drive to check.
filename File(s) to check for fragmentation (FAT only).
/F Automatically Fix file system errors on the disk.
/X Fix file system errors on the disk, (Win2003 and above)
dismounts the volume first, closing all open file handles.
/R Scan for and attempt Recovery of bad sectors.
/V Display the full path and name of every file on the disk.
/L:size NTFS only: change the log file size to the specified number of kilobytes. If size is not specified, displays the current log size and the drive type
(FAT or NTFS).
/C Skip directory corruption checks.
/I Skip corruption checks that compare directory entries to the
file record segment (FRS) in the volume's master file table (MFT)Example:
on May 20, 2010 | Computers & Internet
My certified data laptop quit all of a sudden and turning it off and on or even removing the battery does not help it just goes to safe mode or open windows normal and the screen stays blank
Symptoms seem to indicate either corrupted or missing driver files (probably other corrupted files on hard drive as well).
You can boot into Safe Mode, then run Command Prompt, and type the following to try to correct corruption on the hard drive:
chkdsk c: /r
You will get a message telling you the drive is in use, and would you like to run on next restart. Type "Y" and hit enter, then restart the computer. Depending on the size of your hard drive, this could take hours to run, but be patient.
If this does not resolve your problem, the next thing to try is (in Command Prompt again) "sfc /scannow". You will need your installation disks as this program does a full System File Check and will ask for your installer CD/DVD to replace any missing or corrupt System files it finds.
I hope this helps...
Dec 30, 2012 | Computers & Internet
File system error 65535
I would suggest you to run a SFC scan on the computer.
1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.The access the drive by typing command for example - if you are facing trouble in C drive type C:
2. Type the following command, and then press ENTER:
sfc /scannow
The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
How to use the System File Checker tool to troubleshoot missing or corrupted system files on Windows Vista or on Windows 7
http://support.microsoft.com/kb/929833
Also try running a Check disk on the computer.
Check a drive for errors
http://windows.microsoft.com/en-us/windows7/Check-a-drive-for-errors
Hope this information is helpful. Please let us know if you require further help.
Regards
Sep 10, 2012 | Western Digital Elements powered by WD 320...
When I was trying to boot the system the following error is getting flashed on my screen and asking me to press F4 to continue. pri master hard disk: S.M.A.R.T. command failed
this is a warning your hard drive is about to fail
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Dec 01, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Safeboot corrupted (error 92h)
Check the BIOS setting to see if the hard disk is detected. If not either the hard disk controller or the hard disk is faulty.
First thing I would try is to remove the hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services.
Jun 24, 2010 | HP EliteBook 2530p Notebook
Many programs of control panel and properties not working
You seem to have a bad one there and only 3 of th following could be the cause:
1.) Virus infection. Your PC has been infected with a vicious virus, that has spread on everything that you have beed running. This includes programs, partitions, external devices like memory sticks and hard drives. The virus renderes the system unusable thus none of your applications want to open. In my honest opinion, your hard drive needs to be removed from your machine and scanned on a machine that has a good updated anti-virus installed that can find and take of all the viruses. You might consider doing a re-installation of your operating system
2.) Hard Drive defect. Your hard drive might be broken thus many files that lie on the broken areas on your hard drive might be rendered corrupt and thus they don't open. In this case, a bootable hard drive test can reveal if you have bad sectors or other faults which might case this.
3.) Operating system corrupt. Due to loads of installations, file moving, deleting and re-installing new software, copying new data, browsing the web, unscheduled shut-downs, no regular maintainance and cleanups, your system has rendered itself unusable. In this case, download high rated "Operating system maintainace tools" like a Disk Defragmenter, A Registry Repair and Cleanup tool, a Performance Tune-up Program and other useful utilities. What you might ned to do is to run a check disk before you run all those programs on your hard drive. To do this, open command prompt with run (type cmd into run and press enter), then type "chkdsk /r C:" without the quotes. Confirm prompt questions with "Y" or "Yes" and reboot your machine. A check disk will run and when it is done it will restart your machine again then goes into windows normally.
May 24, 2010 | Microsoft Windows XP Professional for PC
Can read the drive, directory corrupted
just run chkdsk command to recover your directory structure,
Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Apr 22, 2010 | Hitachi hts548080m9at00 80 GB Hard Drive
Error: windows root>\system32\ntoskrnl.exe
Issue: NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows.
Solution: Keyboard issue This issue has also been known to be caused by a short in the ground wire in the keyboard cable. Make sure this is not the cause of your error by replacing the keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Miscellaneous corruption Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration. Additional information about doing this can be found on document CH000626.
Corrupt boot.ini file This issue is often caused when the boot.ini is missing or improperly configured. This issue often arises after a user has recently added or removed an operating system on the computer or added or removed hard disk drives in the computer. Make sure the line pointing to the operating system and it's drive and partition is properly configured in the [boot loader] and [operating systems] section. Additional information about boot.ini can be found on document CH000492.
Missing boot.ini file Microsoft Windows XP users: If the boot.ini is severely corrupted or missing a user running Microsoft Windows XP can rebuild the boot.ini to resolve this issue. Additional information about rebuilding the boot.ini can be found on document CH000648. Microsoft Windows NT and Windows 2000 users: To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
  1. Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
  2. In the setup menu, type R to start the repair.
  3. When prompted for the ERD diskette insert the diskette and inspect the startup environment.
Missing or corrupt ntoskrnl.exe file If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer.
Windows NT installed on a partition bigger then 7.8GB If you are running Microsoft windows NT 4.0 on a partition larger than 7.8GB this issue can occur if the boot files are located outside this limitation. When this error occurs your computer will have the error message as shown below. OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file. If your system partition is larger than 7.8GB you will need to delete the partition and recreate the partition to 7.8GB or less. Additional information about this issue can be found on Microsoft KB Q224526.
Corrupted hard disk drive or severely corrupted Windows Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
If after trying all of the above steps you are still encountering the same issue it's likely that Windows is severely corrupted and it is recommended you attempt to reinstall Windows. Additional information about erasing the computer and starting over can be found on document CH000186. Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Oct 18, 2008 | Computers & Internet
How do I...
Related errors:
Cause:
Keyboard issue
Solution:
Keyboard issue
OS Loader v4.01
Oct 09, 2008 | Dell OptiPlex GX110 PC Desktop
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
61 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
