Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Bad Mits capacitors
I have the blue flickering screen problem with my wd52525. I disassembled the electrical chassis and found 4 bad capacitors. I have ordered enough to replace all of the potential trouble capacitors because I don't want to have to do this again.
After I replace the capacitors I will try to reassemble the tv but to tell the truth, I'm not real confident, lol.
Is there a detailed description for putting this thing back together? If not, it may end up in the landfill!!!
    Problem Solver:
  • 16 Answers
If your going thru all this trouble, be sure to check the 4 capacitors on the DM board (1000mf/16volt), the 4 caps on the formatter board (1000MF/16volt) and the 2 caps on the power supply board (3300mf/10 volt) Mitsu recoomends changing the 1000mf caps to 680MF/16volt.
It is kind of a pain to change these.
good luck
Posted on Jun 12, 2008
  • Mitsubishi Master
  • 8,617 Answers
You can get the full service manual at the following link that will show you how the chassis is removed and then its just reverse the proceedure. Heres the link.
Posted on Jun 11, 2008
My lenovo t400 has screen flickering when ever i on the laptop flickers continously booting stops left side some part of screen goes light blue
Sounds like a problem with the video adapter chip. The chip might be either defective or experiencing bad connection with the motherboard. In order to fix this problem, you will need to disassemble the notebook, pull out the motherboard & inspect the video chip & its connection points to the motherboard. If the video chip is defective, you might have to replace the motherboard.
Apr 10, 2011 | IBM Lenovo ThinkPad T400 7417 Notebook
Monitor shows lines and flickers
check for any magnetic fields if not check the power cable for any voltage fluctuation..or else you may need to change the monitor...
Mar 01, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
T41 will turn on and then immediatly go to sleep
Check that the hard disk is in working order.
If the hard disk will not spin up... sometimes the system will just shut off.
It may be a bad motherboard.. usually a damaged or failing capacitor will cause the system to not stay powered up long enough.. capacitors usually create a steady flow of electricity... if it can't hold a steady charge it will behave as you've mentioned.
Dec 08, 2008 | IBM ThinkPad T41 Notebook
Mitsubishi wd52525 capacitors
well capacitors are located on the chassis but only the high voltage capacitor can cause electric shock,dont be afraid,u can discharge the current on it.
Jun 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 55 inch 1080 tv
Is it flashing a two digit code such as 34 as thats a common fault with the WD52525 V26 chassis for a lamp abnormality caused by two bad capacitors on the PWB PCB
Jun 17, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Bad capacitors
go to the link below, they have the factory manual with fetailed photos of the disassembly and reassembly of your unit.
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen with flickering horizontal lines
Sounds like the 1000uf capacitors on the FMT board need replacing. This is a common symptom with that chassis. There are three 1000uf caps that fail on that PC Board
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue flickering light, no audio
You will need the service manual in order to get that chassis out. once out it is an easy repair to replace the capacitors yourself. I just did one the other day. You will need the service manual for sure it will save you alot of money on repairs. heres a link where you can get the factory service manual.
Mar 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flickering blue picture
I finally got around to dismantling the TV. This is no mean task. The chassis is tethered to the rest of the set my over a dozen wiring harnesses and a few of these cannot be disconnected near the chassis but instead require removing the “right support” near the air duct and taking the shield off the lamp ballast. Once the chassis assembly is out, it is a further significant task to disassemble it to get at the various PWBs (POWER, FMT and DM) having the suspect caps. I’m sure reassembling everything will be a fun job!
I have not yet had a chance to fix and reassemble but I wanted to post this no as I’m not sure when I will get around to it.
I did find six of the fourteen known-problem caps to be visibly bulging -- both 3300s and two of the four 1000s on the PWR PWB plus two of the four 1000s on the FMT PWB (see photos below). Ironically of the four 1000s on the DM PWB, which I have heard are the most common to go bad, were bulging and I considered skipping these as the DM it is the toughest board to extricate from the chassis, however I figured I had come this far and I would just as soon replace all twelve 1000 uFs as the parts cost $0.23 and I really never want to have to do this again.
If I had to bet, the two 10V 3300uF caps on POWER board, which were actually leaking black goo, are the actual culprits, but with four of the 1000 uFs also bulging it is probable only a matter of time until they failed as well.
Here is the POWER PWB with the known-problem caps (C9A37, C9A38, C9A51, C9A52, C9A61 and C9A62) highlighted:
here's the FMT PWB with the known-problem caps (C8F19, C8F21, C8F22 and C8F27) highlighted:
and the DM PWB with the known-problem caps (C81A2, C81A3, C81B3 and C81B4) highlighted:
Here are close-ups of the bulging caps (C9A37, C9A38, C9A52 and C9A62) on the POWER PWB:
And here are close-ups of the bulging caps (C8F19 and C8F27) on the FMT PWB:
Jun 19, 2007 | Mitsubishi WD-52525 52" Rear Projection...
There is a 5, 9 & 12 volt dc regulator on the chassis that could be causing this. Three legged transistors on small heat sinks. I f you look at the chassis from the rear of tv, is two boards.The one on the left has these reg. transistors. Usually the 9v regulator is bad and a 35ufd @ 50v capacitor near it is bad. From the tuner as ground check the third leg on the regulator for less than 9v dc.
Jun 18, 2007 | JVC AV-60D501 60" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
112 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
