Question about Intel Motherboard
Cf 29 touchscreen
I think your diagnosis of my touchscreen is correct, any idea how to get to the connection? Panasonic Toughbook cf-29
  • Wolfganglump Sep 20, 2008
    Thanks for the help. Turns out Panasonic covered it under warranty!!!! It was just a connection. Minor problem and is all better now.
  • 2,028 Answers
The connection to the board should be under the panel with the speakers, at the top of the keyboard. (that's where it is on my cf72) Also check the connection on the touch screen by pulling the front case from around the screen. There are screws hidden under the small rubber bumpers on the lid.
Posted on Jun 12, 2008
Touchscreen windows xp pro
On the Panasonic Toughbook CF29,
the Touchscreen is the same as the "Mouse".
So you have to load the Touchpad/Touchscreen
Driver, not just the Touchscreen driver by itself.
The driver for the CF29 MK2 is located at this link:
Good Luck!
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jun 21, 2014 | Panasonic Toughbook Cf-29 Laptop/notebook
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Touch screen doesnt work on my cf-29
    Your Model CF29NWQGZBM the letter "W" indicates that this is a T/S (TouchScreen) Model.
    Please verify that the "TouchScreen" is "Enabled" under the BIOS. I recently purchased about a dozen CF29's where there were absolutely NO scratches on the LCD. The reason WHY was because the TouchScreen had been DISABLED at the BIOS level.
    I can also share with you another experience I had recently. I purchased approx. 15x CF29 models and every single unit had a defective TouchScreen. When I called Panasonic Canada I was told that since the units were no longer under the three year manufacturer warranty there was nothing they could do about it but that they were aware of this defect and it was a known defect.
    I hope this information helps.
    Regards from an authorized Panasonic Toughbook Dealer located in Montreal.
    Jan 23, 2014 | Panasonic CF-29 (CF29NWQGZBM) PC Notebook
    How do i enable touchscreen on panasonic toughbook cf 30ctqazbm
    The first thing I would try on any Panasonic Toughbook with touchscreen would be to enter the BIOS upon start-up by pressing the "F2" function key. When you are in the BIOS, there is a setting on the 2nd screen tab "Main" which says "Touchscreen:". This should be set to "Enable" instead of Disable. Then you press the "F10" function key and the message: "Save configuration changes and exit now?". Press "Yes" and the toughbook will reboot and your Touchscreen will be enabled at the BIOS level.
    Good Luck!
    Regards from Richard, Montreal based Panasonic Canada Authorized Toughbook Dealer since 1989.
    Dec 27, 2012 | Panasonic Toughbook CF-30 Notebook
    Cf-30 disable touchscreen
    On all Panasonic Toughbook Notebooks,
    you must get into the BIOS by pressing
    the F2 Function key when you turn on the
    Toughbook as it is booting. Press F2 repeatedly.
    This must be done in the 1-2 seconds before
    Windows starts to load. Then you will see
    Touchscreen usually on the 2nd page with the
    word "Enable". Simply select enable and press
    "Enter" and the choice between enable and disable
    will appear. Then select "Disable" with the cursor
    and then press Enter. Finally you need to
    "Save and Exit" the changes in the BIOS.
    That is it. Good Luck to you.
    Panasonic Toughbook Authorized Dealer since 1989
    Nov 13, 2012 | Panasonic Toughbook CF-30 Notebook
    I have a cf-29 and my screen changed to black with weird lines going top to bottom. i was thinking it might be the video card any help would be great.
    With any model of Panasonic Toughbook, the proper diagnostics would be to plugin an external monitor when the Toughbook in powered off, then turn on the power on the external monitor first and then finally turn on the Toughbook. If the problem is the video card then no image will display on the external monitor.
    If you get an image on the external monitor, then the problems is the internal LCD screen.
    The external monitor connects on the back or rear side of the CF29 in the external monitor port or VGA connector. This connector is typically "blue" in connector and has 15 pins (3 rows of 5 pins).
    Good Luck and Regards from:
    Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
    Sep 08, 2012 | Panasonic Toughbook CF-29 Notebook
    Is this a touchscreen?
    The following Panasonic Toughbook CF73
    models are equipped with TouchScreen:
    • CF73N3LTSKM
    These are the units listed on the Panasonic Canada
    website as having TouchScreen. Other models may
    exist but have not been listed.
    I hope this helps.
    Good Luck!
    May 18, 2012 | Panasonic Toughbook CF-73 Notebook
    Panasonic CF-29 touch screen do not work
    Do you have the driver for it? Try install the driver on your PC and see.
    Apr 03, 2012 | Panasonic Toughbook 29 Touch (P/N...
    Touch screen do not work
    Have you checked under the device manager in to make sure that all your peripherals are recognized or enabled in the bios
    A: Activate Touchscreen in Bios
    B: Reinstall all drivers
    C: ensure OS is recognizing the peripherals.
    Good Luck
    Intel Motherboard Logo
    184 people viewed this question
    Top Intel Computers & Internet Experts
    Alun Cox
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
